Go to Post FIRST will continue searching for rules and procedures to keep us from hurting ourselves. However, none of this will substitute for judicious application of common sense. - Richard Wallace [more]
Unread 16-03-2010, 09:57
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
classmate charger power requirement
I am at work thinking about this so I don't have the charger here. Can anybody tell me what the input power requirement is for the classmate pc's charger? What is the output voltage?
Thanks
Unread 16-03-2010, 10:43
Re: classmate charger power requirement
This is from memory, so someone with the charger handy would be a better source. From what I remember:
Input
  • 100v-240v AC
  • 1.2A
Output:
  • 2 Amps (50 watts is enough)
  • 20v output
P.S. I checked when I got home and I'd remembered correctly.
Unread 06-01-2011, 19:34
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Does anyone know if it's center pin positive or negative? This is actually quite urgent, so if anyone can find out that'd be great.
Thanks
Jacob
Unread 06-01-2011, 19:51
Center pin positive
P.S.
Here's a better picture and more to the point, a crop of just the power info.
ID:	9586  Click image for larger version
Unread 06-01-2011, 20:26
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Mark,
What in that image indicates it's center pin positive? Or have you taken to the practice of including red herrings in your post as well
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 06-01-2011, 20:42
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
There's so many symbols on that label I really had to look to find it.
It's to the right of the DC output spec, right below the text "50-60Hz".
(Unfortunately the scanner has a very short focal length, and so the distance offset by the rim of the charger was enough to make the label hard to read.)
-- Marshal Horn
Unread 20-01-2011, 11:27
Just to round things out.
Here is the power required by the 2011 Classmate.
Slight differences from the 2010 model.
Still just as busy as the other one.
ID:	9744  Click image for larger version
Unread 31-03-2011, 00:16
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
I need help. Our team lost the Classmate charger again second year in a row. We have the original classmate 2010. Does anybody know which AC/DC adapter I should purchase as a replacement from www.ctlcorp.com?
They have
http://www.ctlcorp.com/v4/p-1074-ac-...r-2go-uw1.aspx
http://www.ctlcorp.com/v4/p-904-ac-a...9-and-e10.aspx
http://www.ctlcorp.com/v4/p-1076-ac-...te-pc-e11.aspx
Please don't call me Mr. Ed, I am not a talking horse.
Unread 31-03-2011, 00:38
Unread 31-03-2011, 00:40
Ed Law's Avatar
Originally Posted by Joe Ross View Post
Thanks Joe for the quick reply. This is the one on back order. Does anybody know of any other source I can get one. If I use the 19V 2.1A output 2011 charger, will it fit and will it damage the Classmate PC?
Unread 31-03-2011, 08:32
http://www.wireless.att.com/cell-pho...id=vPbPJ5OAGA7
Price is $5 after an instant $20 discount and shipping is free.
I bought two of them as spares. They've helped teams at both regionals I attended.
Thanks to user silverD for the pointer.
Unread 31-03-2011, 09:45
Ed Law's Avatar
Thanks Alan. I have one last question.
According to the image Mark McLeod posted, the 2010 classmate charger output is 20V 2A. The 2011 classmate charger is 19V 2.1A. This Kensington Netbook Wall Charger is 19V 2.5A according to SilverD.
I am not an electrical person. We have the 2010 classmate. Is it okay to use this Kensington charger?
Unread 31-03-2011, 09:58
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The Classmate Power adapters FIRST is providing at the Driver's Stations (or was intending to provide, they were not there at Peachtree, we were provided with outlets instead) are specified in the manual as the 19V version and compatible with both 2010 and 2011 KOP Classmates.
Unread 31-03-2011, 15:42
We've used both versions of the Classmate charger on our 2010 Classmate without any problem.
Unread 13-01-2012, 12:23
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
Rather than starting a new thread I thought it might be best to revive an old one. We seem to have lost our classmate power brick between last season and this season. We have one of the E09 classmates. Based off the pictures above the model number is an ADP-40MH AD. a quick google search finds this adapter. http://www.amazon.com/Replacement-Ad.../dp/B005NU6A9M
For those of you with working classmates do you think this is the right adapter and tip? supply voltages look correct but i wasn't sure about the tip size or polarity.
Thanks.
Help! We lost our Classmate Charger Ed Law General Forum 6 03-03-2011 11:43
Power your Classmate PC with this cable sanddrag Electrical 15 22-03-2010 14:04
Drawings/CAD requirement? Numbers General Forum 6 09-02-2010 22:35
Passport Requirement News dtengineering General Forum 0 25-02-2007 21:33
SPI Requirement To Purchase archiver 2001 3 24-06-2002 00:33
