Go to Post Gee, I wonder if AndyMark has a wedding gift registry? - KathieK [more]
Unread 06-01-2011, 23:44
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Re: 6WD vs 8WD
The final speed, as well as the acceleration are functions of the angular velocity and acceleration of the drive shaft (respectively), as well as the wheel radius.
Think about a wheel with radius = r and a driveshaft with some torque T. We then sum the torques about the center of the wheel and get Fa*r < Fsfmax*r (theta is ninety so it goes away sin(90)=1). Cancel the r, plug in uFn for Fsfmax, and you have your max Fa to not slip. Use T = F * rsin(theta) and you get the max torque from the driveshaft to be traction limited. From there it's just some basic ratios back to the torque output of the motor and that ratio is your desired gear ratio.
Now, this assumes that you have a perfectly efficient gearing system, and that your wheel has no mass and therefore no moment of inertia to slow the acceleration, but it gets you close.
For speed based, do the same basic thing only with rpm instead of torque.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
What does it take 6WD/8WD to be successful? TEE Technical Discussion 26 06-05-2010 08:30
pic: Rastogi 8wd Iteration 1.2 Akash Rastogi Extra Discussion 56 05-05-2010 15:16
pic: Sheetmetal 8wd Akash Rastogi Extra Discussion 16 02-05-2010 15:38
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
8WD drivetrain? David Sherman Technical Discussion 16 09-04-2006 17:32
