Go to Post The only thing a team needs to survive is people who want it to survive. - Ryan Foley [more]
Unread 07-01-2011, 00:25
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
KOP Speculation
This year's KOP is a little different from previous years.
Originally Posted by FRC KitOfParts Blast
KOP Dimensions: Here’s what you can expect when you pick up your Kit of Parts…
Veterans will receive the following packages:
1 tote
- 49 lbs
- 27” L x 18” W x 13” H
1 box
- 25lbs
- 36” L x 8 ½” W x 4 ½” H
1 battery
- 14lbs each
- 7” x 3” x 7” each
4 separate items, each weighing less than 5 pounds and smaller than a paperback book.
For one thing, why is that one tote so big? What's in there? For another, what are the mysterious paperback-sized items? Might we have specialized wheels in this game? They said that the veteran kits will weigh 95 pounds, so if you subtract out the weights of the totes and divide by four, each of the mysterious items is 1.75 pounds... so probably closer to 2 pound items than 5. This seems a little heavy for wheels, but they also sound far too heavy and small for game pieces.
Any thoughts on what they could be? Does this have anything to do with speculation of tethered robots or a train-related game? Community, what do you think?
Unread 07-01-2011, 00:27
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: KOP Speculation
Special wheels/mechanisms for rails? like roller coasters? haha just... speculating
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 07-01-2011, 00:32
Re: KOP Speculation
Deflated game objects, miniature motors, the FedEx donation, or some such small item. The Mabuchi motors were loose outside in at least one year, for example. Depending on the game object, it might be possible to get one under paperback size.
The tote seems like the standard size, but it's likely to be better filled this year (and some of the past ones were packed tight, some were very loose).
The long box is the Kitbot, if tradition holds.
Unread 07-01-2011, 00:34
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: KOP Speculation
probably not the fed ex donation... that's called out specifically further down in the e-mail:
Teams attending bag and tag events will receive 1 box:
- 6lbs
- 14” x 14” x 6”
Teams attending traditional events (non-bag & tag) will receive aFedEx Envelope (goes to teams attending standard events)
- <1lb
- About the size of a big envelope
Unread 07-01-2011, 00:47
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: KOP Speculation
Servos? Jaguars?
Unread 07-01-2011, 00:55
h1n1is4pigs's Avatar
h1n1is4pigs h1n1is4pigs is offline
h1n1is4pigs has a spectacular aura abouth1n1is4pigs has a spectacular aura about
Re: KOP Speculation
Originally Posted by davidthefat View Post
Servos? Jaguars?
jaguars are like half a pound each so i doubt it. may be they contain a flux capacitor and plutonium
or maybe they contain lead weights
Unread 07-01-2011, 01:16
Joining the 900 Meme Team
FRC #0079
Re: KOP Speculation
I'll give you my prediction in just over 35 hours.
Unread 07-01-2011, 08:14
GaryVoshol's Avatar
Cogito ergo arbitro
Re: KOP Speculation
Isn't that the standard tote size? With the Choice program, probably all standard KoP items fit in one tote this year; it might be a little heavier than when all the previously-supplied items would be divided between 2 totes. Motors are probably the majority of the weight. (Remember, past rules specified that except for any additional CIM's allowed, motors used on the robot had to be from the current KoP.)
Separately packaged items are usually those that arrived too late to put into the tote. Probably the size and weight is that of the largest one. I wouldn't read too much into this.
(since 2004)
Unread 07-01-2011, 08:29
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: KOP Speculation
Perhaps the smaller boxes are CIM motors donated in their own packaging? Maybe some new Electronics gear that FIRST didn't want to package in with the rest of the KOP? Those are the only things that come to mind that are that small but also that heavy.
Or, OMG, what if they give us one of each (if there are multiple) or more than one game piece? That'd be something right there. (For those of you that weren't around in 2009, finding replacement game pieces was nearly impossible unless you were adventurous enough to go through every Walmart in the surrounding area and search through the clearance Aisle, and in 2010, we realized that not all size 5 soccer balls were created equal...)
-Dustin Benedict
Unread 07-01-2011, 08:39
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
Re: KOP Speculation
http://www.toysrus.com/product/index...LAID=603713622
Unread 07-01-2011, 09:11
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
Re: KOP Speculation
Maybe we'll be receiving a Mr.Fusion this year .
But Sirusly,
I'm surprised were going down to 1 bin for Veterans...
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Unread 07-01-2011, 09:20
thefro526's Avatar
Mentor for Hire.
Re: KOP Speculation
Originally Posted by dag0620 View Post
But Sirusly,
They've been talking about reducing the kit size for Veterans for the last year or two. I can't remember if we got two bins last year or not, but I know whatever it was - it wasn't much. Some vendors are reducing what they're putting in the KOP or making it available to those teams that request it to keep the cost down. You've also got to figure that a New Control System takes up nearly a tote in itself between the CRio, Assorted Modules, PDB, Digital Side Car, etc.
-Dustin Benedict
Unread 07-01-2011, 10:01
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: KOP Speculation
Last year was two totes for the veterans.
1058 PVC Pirates 2016 - xxxx
Unread 07-01-2011, 10:31
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: KOP Speculation
Last year was two just-over-halfway-filled totes for the veterans.
Hi!
Unread 07-01-2011, 10:45
Re: KOP Speculation
Lets also keep in mind that most years we've gotten small/delicate parts in their own packaging or envelops. One great example is the accelerometer and Gyro. small padded envelop, smaller than a book and less than 5 lbs. Remember, we have an upper limit on weight, not a lower limit - so don't discount the jaguar theory, h1n1is4pigs. Half a pound is still less than 5 lbs.
KOP Jack Gillespie Pneumatics 3 31-01-2010 18:13
2006/2007 FVC speculation? Billfred FIRST Tech Challenge 24 13-09-2006 13:26
KOP photos? Gary Dillard Rumor Mill 13 04-01-2006 20:56
8 days before we know....Where's all the speculation!? archiver 2001 3 23-06-2002 22:11
Isn't it about time for some speculation? archiver 2000 0 23-06-2002 22:05
