#7
Re: altitude sensors anyone?
Kinect? (http://www.youtube.com/watch?v=4EGQZ...eature=related)
Failing that, maybe a poor man's kinect? Maybe with a strong IR emitter on the bottom and an IR sensor, you could determine from the brightness of the received IR how far away from the ground you are. This would depend on how much the ground below absorbs IR so it might not work if you don't know what you'll be flying above. |
| Does anyone know what sensors we can use? | gilkeedman | General Forum | 3 | 30-01-2010 04:20 |
| Wheel Speed Sensors / Vehicle Speed Sensors | chitu | Technical Discussion | 11 | 12-01-2008 02:46 |
| where can we buy hall effect sensors or gear tooth sensors | amirjpl | Electrical | 3 | 13-02-2006 11:02 |
| Can anyone tell me the proper code for line sensors | thelastride | Programming | 1 | 14-02-2004 13:47 |
| Anyone using sensors??? | Willum | Robot Showcase | 42 | 25-02-2003 18:57 |
