Go to Post I have never before seen the words "smaller" and "Saturn V" used in the same sentence. Wow. :yikes: - DonRotolo [more]
Unread 06-01-2011, 19:19
remulasce remulasce is offline
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
pic: BCRDrive- everything Nonadrive does, except comparable!
Unread 06-01-2011, 19:20
AdamHeard's Avatar
Lead Mentor
Re: pic: BCRDrive- everything Nonadrive does, except comparable!
I would recommended the shaft lay parallel to the floor in the omni configuration, so the omni wheels will operate more smoothly.
You could retain the use of pneumatics with a similar mechanism.
Also, with the shown mechanism, if the pivot attachment points and the drive hub are not all at the same height, the current setup will result in two different wheel pod angles for each drive hub angle.
Do you plan on running a relatively unmodified drive module that 294 usually runs?
Unread 06-01-2011, 19:33
Yeah, the angle is overexagerated in the drawing. Having the omnis as close to level as possible with the treads compensating with more angle might work better, but the quality of my pencil limits my design-in-calculus-class abilities. In a real build, the non-contact wheels would be barely off the ground at all. I hadn't thought of it before, but yes, the driving hub should be at the same height as the connectors, unless we did something weird with the arm linkage. I had thought about pneumatics, but didn't know if they would be strong enough, and having a motor gives a lot more control of the angle. In tread mode, it might be nice to put the omnis down just a little bit to make it easier to turn. Some sort of variable traction control.
Right now we want to stick with the Breakaway base, but that could change pretty quick on Saturday morning.
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
Unread 06-01-2011, 21:09
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Do you know if the common traction wheels used in FIRST perform the same when tilted a couple degrees? I imagine that it probably wouldn't because (unlike AM omni's) their flat to accomidate the tread.
I made up a design sort of similar to yours a while ago. It's not plausible for a variaty of reasons. Namly: weight and completity. Even so it was fun to do.
http://www.chiefdelphi.com/forums/sh...ad.php?t=86467
Here it is for your viewing pleasure. (The last post in the Thread)
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 06-01-2011, 22:00
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
And all this on the back of a "Cookbook for circular motion problems" page. Good recycling but better luck in the 2011 robot design.
Unread 07-01-2011, 11:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This may actually be feasible if pneumatic wheels were used instead of standard traction wheels. Traction wheels would lose to much traction if tilted in that manner. Pneumatic wheels are rounded; so it's just a matter of finding the right pairs of wheel sizes that will only contact the ground when it's desired.
On field, the rotation joints would take a beating. I almost want to say they'd have to be made out of steel or solid aluminum blocks.
Also, when designing this type of drive train in CAD, account for the fact that most of the time the bumpers cannot tilt or raise/lower outside of their specified zones. Thus an outer frame would be needed that connects to the inner frame.
Great idea, I think.
GitHub
Unread 07-01-2011, 11:59
Brandon Holley's Avatar
At the very least, a creative one.
Keep exploring this idea! Develop it, iterate it, keep the process going, even if you don't end up using in competition. It will still be very beneficial to keep working on it.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 10-01-2011, 08:17
ThaineP
Posts: n/a
That's a really cool idea!
If you do, I'd say that you should have a frame around it so that the bumpers don't tilt out of the bumper zone.
Thaine
Unread 10-01-2011, 08:43
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
that is a really good idea but are you going to be able to do that with only 4CIM motors and i would love to see that out on the feild
Unread 10-01-2011, 09:08
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I've played with a robot that had a very similar drive train way back in 2000, it had hard plastic wheels on the outside, high-traction tread in the middle, and saw blades on the inside for ice traction. Not used in FRC competition, unfortunately.
I would recommend using pneumatics to deploy/retract the sides. Have fun with it!
Unread 10-01-2011, 12:34
mryeagle mryeagle is offline
AKA: Jeff Yeagle
FRC #2229 (ROBOSHOP)
mryeagle is an unknown quantity at this point
neat idea..
no reason that the pair of wheels couldnt be mounted to the same output shaft of a toughbox or similar.. (given that it is of sufficient length)
however..
to make it work well I would think that decreasing the size of the high traction wheels JUST ABIT would be beneficial and planning to tilt the mechanism so that the (the high traction wheels) came into contact with the floor) would be of advantage..
i would also suggest that using pneumatics to drive this would be the best plan of attack..
not sure if we will explore this topic further (team 2229) but its neat..
thanks for sharing.
Who's robot does everything? LightWaves1636 General Forum 52 30-03-2006 21:52
Not building to do everything?? TriggsJr General Forum 1 02-03-2006 09:06
FIRST for everything! Cpt_Dave_Lister General Forum 1 22-02-2006 11:13
New To Everything jmwinston General Forum 16 03-10-2004 23:08
