Go to Post You're never too cool for a giant conga line around an arena. - Michelle 236 [more]
Unread 07-01-2011, 17:24
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
Re: Cypress PSoC system
Originally Posted by PortugazD.Ace View Post
no. I mean like getting information about the surrounding environment to help the robot navigate during autonimous mode(Sorry if I misspelled something.)
If the PSoC is being used connected to the classmate/DS, you will not be allowed to use it to help your robot navigate in autonomous (This is very likely a rule this year, and is also enforced in the FMS).
If you are talking about using it on the robot, you're probably better off just connecting the sensor to the cRIO or the Jaguars (if using CAN), unless you need the PSoC to offload some calculations from the cRIO.
Analog Out on the Cypress PSoC (enhanced modeO gokul Programming 5 23-02-2010 14:05
LEDs on the Cypress PSoC mcbean Programming 4 21-02-2010 15:55
Cypress Programmable System-on-chip Solution scottbot95 Control System 3 08-02-2010 20:13
Cypress PSoc Programmer Port Selection problem Steven_585 FRC Control System 2 23-01-2010 23:06
Cypress Programmable System-On-Chip Solution? 1jbinder Electrical 5 12-01-2010 22:13
