Go to Post FIRST is all about helping eachother and team work, isn't it? - vadyr [more]
Unread 07-01-2011, 14:14
Re: First team with swerve drive?
The closest I know a team came to this task would be 469 in 2007.
4wd independently steered, independently driven (and 3 speed shifters).
However, it was motor in module so was not infinite rotation.
If slip rings were permitted, could this design be modified to be a true Unicorn drive ?
Unread 07-01-2011, 14:49
Jared Russell's Avatar
Taking a year (mostly) off
This year, team 1640 had 4 pods, each driven coaxially by its own CIM and each steered by its own Window motor.
Unread 07-01-2011, 15:00
That sounds like a true Unicorn drive, no?
Unread 07-01-2011, 15:45
MCahoon MCahoon is online now
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Originally Posted by JVN View Post
The Unicorn drive?
Could you provide some context for this name?
Unread 07-01-2011, 16:00
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
It's unatainable.
Like a unicorn you can never attain it.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 07-01-2011, 16:53
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
4 wheel swerve with independent steering and drive is called "King Crab."
It may have been coined that by Kaptain Krunch.
Chiefdelphi had this setup in 2001....plus it was a climbing swerve with triangular treads. Making it truly difficult was the motor selection. They had two drill motors, two FP motors, two window motors and two seat motors. I believe this exhausted their motor supply forcing them to deploy pneumatics for the first time since their inception in 1996.
That's tough.
Team 857 built the first "Kiwi" drive in 2002. They also coined the term kiwi....originally to disguise the Killough Drive Base origins. Design secrecy was a little more common back then.
Full disclosure, I was on 857 and coined the term kiwi with my fellow team members.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 07-01-2011, 17:11
So Unicorn would be King Crab with coaxial drive (or slip rings) and US MA3 or Austria Microsystems AS5030 encoders
Unread 07-01-2011, 17:42
Gdeaver Gdeaver is offline
FRC #1640
1640 did 4 wheel independent steering with each wheel independently driven and continuous rotation on all wheels with no gaps in the absolute rotary non-contact sensors and implemented a least distance algorithm to determine whether to reverse direction and rotate a little or make a longer rotation in 2010. It was a major effort but it worked and has amazing capabilities. However, we still need to work on the presentation of all those degree's of freedom to the driver. We call it the " PIVOT DRIVE". To any other team that wants to go down this path I would ask them to seriously evaluate their resources to accomplish it. A page with a little description.
http://wiki.team1640.com/index.php?t...VI_Drive_Train
Yes, I am very proud of the group of students that made this happen.
Unread 07-01-2011, 17:56
Chris is me's Avatar
AKA: Pinecone
And for good reason! 1640's technical achievement is both underrated and can't be understated. Especially impressive is their extensive documentation - often more valuable in engineering than the design itself.
Unread 07-01-2011, 18:03
foozie's Avatar
foozie foozie is offline
AKA: Matt Howard
FRC #1124 (The ÜberBots)
Team Role: Webmaster
foozie is an unknown quantity at this point
Team 1124 had swerve drive in 2010. There was a front and back window motor steering with four independent drive motors. It supported swerve, traverse, car drive, and 90 degree swerve drive. It worked pretty well, as it won us Rockwell Innovation in Automation at Hartford and Hartford Regional.
Unread 07-01-2011, 18:22
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
team 159 had one around 2001, although it was not co-axial and it did catch fire during finals.
Unread 07-01-2011, 18:27
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Flaming Unicorn Drive!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!
^that would make a good signature.
^ yes, I am aware that this wouldn't be true unicorn drive, but still.
Unread 14-02-2011, 16:10
Racer26 Racer26 is offline
I believe 1334 had a Unicorn drive in 2010. It had 4 independently steered units, with independent speed control on a per wheel basis (IIRC).
1075 has only ever done 2+2 swerves, where the angular position of wheels is controlled in pairs. We did however invent DSSwerve.
Unread 14-02-2011, 16:17
Did it also have :
- unlimited rotation of the steering mechanism and the wheel angle sensor
- no "dead zones" in the wheel angle sensor
? if not, it was not Unicorn.
Unread 14-02-2011, 16:22
I believe so.
pic: Team 2220's Swerve Drive Chasis Jedward45 Extra Discussion 21 11-01-2011 16:00
Team 2338 swerve drive peer review Creator Mat Technical Discussion 13 17-06-2009 17:45
Swerve Drive with new wheels Carl Green General Forum 0 04-01-2009 18:22
pic: Team 108 - LEGO swerve drive zander_108 Extra Discussion 8 10-04-2007 22:36
pic: My first Lego Swerve Drive Ken Leung Extra Discussion 5 16-08-2006 23:56
