Go to Post FIRST has stated time and again that the program is not about teaching (they always refer to the I and R in FIRST) - Dave Flowerday [more]
Unread 07-01-2011, 18:40
Chris is me's Avatar
AKA: Pinecone
Re: Viable Stair Climbing Drive System?
Interesting idea and nice thinking outside the box.
The first issue I can see is with drive chains - as the front wheel articulates, will the distance between sprockets change? This changes how much chain needs to be between them and throws chains out of tension.
A solution is to chain your pivoting member to a sprocket attached to the actual pivot point - this way the distance between any connected sprockets does not change.
Team 2481 2010 Robot Climbing with Mecanum Drive maddoctor90 Robot Showcase 0 06-03-2010 15:09
crab drive vs. mecanum drive system superbotman Technical Discussion 33 06-01-2010 03:09
pic: six wheel drive articulated stair climber Bertman Extra Discussion 14 01-12-2008 00:47
stair climbing vex robot by myth busters foobert FIRST Tech Challenge 4 30-10-2005 14:38
