Making the Connection
There is a small plastic flange that must be cut off of the connector to make it fit. Both the actuator and the connectors were donated items and the wrong connectors were given to us, so we make do. Small electrical terminal connectors can also be used. Contact us at OSTCNE if you decide you want the donated connectors that you can modify.
| Need a FIRST Robotics control system | kershawrobotics | General Forum | 3 | 07-07-2003 09:49 |
| Under Control Website! New Flash Version! | physicist | Website Design/Showcase | 11 | 22-02-2003 02:41 |
| Ok, how much is the control system worth? | archiver | 2001 | 6 | 23-06-2002 22:05 |
| more control options | smokescreen | Technical Discussion | 17 | 05-03-2002 15:41 |
| goals: how much control? | Pat Sarmiento | Rules/Strategy | 2 | 18-01-2002 19:10 |
