Go to Post It's not all about the offensive "powerhouses", strategy is key. - smurfgirl [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.25 average. Display Modes
Unread 01-08-2011, 12:55 PM
Stevexe Stevexe is offline
FIRST Alumni/Mentor
AKA: Steven Pestana
FRC #0585 (the Cyber Penguins)
Stevexe is an unknown quantity at this point
Question Minibot Standardization (FRC 2011: Logomotion)
Any thoughts on Minibot standardization between teams to make sharing these bots easy between alliance partners? Some sort of standardized shape, volume, size, or mechanism to use to deploy the minibots that would work with a variety of deployment methods?
Unread 01-08-2011, 01:19 PM
darist darist is offline
AKA: David Aristizabal
darist is an unknown quantity at this point
Re: Minibot Standardization (FRC 2011: Logomotion)
good thinking!
No concrete ideas on my part yet, but certainly think this can be a valuable thread!
I also think a standard set of outputs from the robot can be helpful. Then one team team can design a self-contained mini-bot and deployer. The deployer can be attached to any robot as long as the robot provides the right signals, like a relay output, a digital output, and/or a PWM output. So team A can make a mini-bot and deployer (deployer easily attached to another robot's chasis) that uses a piston to deploy. Team B may want to use a digital output to deplay. Team C may want both a digital output and a piston. Team D may want to make the robot deploy with a PWM signal that goes to motor...
Still thinking out loud here, but lets keep the ideas flowing.
Unread 01-08-2011, 01:24 PM
FIRST Alumni/Mentor
AKA: Steven Pestana
A big incentive for standardizing Minibots is the Coopertition score, as well as the ease of use within your alliance sharing 'minibot duty'.
From the game manual:
5.3.5 Coopertition Score (CS)
Any borrowed MINIBOT which scores points by legally triggering the TARGET during the MATCH receives one (1) Coopertition point for the FRC TEAM registered for the event that is affiliated with the MINIBOT.
The total number of Coopertition points earned by a TEAM throughout the qualification matches will be their Coopertition score.
A clarification of some terminology that I found confusing at first:
HOSTBOT – the electromechanical assembly used to carry the MINIBOT. (ROBOT – MINIBOT = HOSTBOT). If a TEAM plays a MATCH without a MINIBOT, then the HOSTBOT is the ROBOT.
Unread 01-08-2011, 01:26 PM
Suggestion that may be practical: Design the interface such that the minibot is on a platform during the match. The platform then provides the launch point. If the minibot is designed to roll off the platform onto the base, or has that option, then it shouldn't matter too much which minibot is loaded on.
So, for the robot side, put a platform to either the base or the pole. If appropriate, make sure that it's notched for the pole. For the minibot side, have a base drive attachment.
Remember, all minibots are 12" cubes or smaller and 15 lbs or under.
Unread 01-08-2011, 01:28 PM
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Standardizing the Minibot
It would seem to be in line with the principles of graceful professional to develop a sudo standard model of a minibot. I would like to elaborate on the why but hopefully we all see this.
What these means is we would need to build a standard 'casing' so that teams could create a standard adapter. To allow for maximum minibot hostbot comparability.
Also a standard umbilical connector to allow for minibot hostbot communication. To allow a go switch / charging port.
Is now an engineer thanks to FIRST.
Unread 01-08-2011, 01:34 PM
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Re: Standardizing the Minibot
I'd love to see something like this done. However, I think it will be up to FIRST or one of the big/respected teams to develop this.
If anyone has any suggestions or wants to propose something, draw it in CAD first and make it publically known what teams are using the standard.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 01-08-2011, 01:37 PM
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
This is a good idea. I think it would work better with there only being a specific size. If someone would create a 'universal' shape, or design, there will be too many ideas, and everyone will want there design to be the 'universal' design.
Unread 01-08-2011, 01:40 PM
I was thinking (dangerous I know) that it would be possible for the minibots to either have a tower contact button or a "you're on your own" dead-man switch, and just be running a program all match that said, wait until X switch toggles to the other position. Minimal programming needed. Or have the NXT in a standard-ish area so a servo mounted on a "flexible" arm could hit the run button easily.
Unread 01-08-2011, 04:01 PM
luc.bettaieb's Avatar
luc.bettaieb luc.bettaieb is offline
AKA: Luc Bettaieb
FRC #1329 (Roborebels)
luc.bettaieb is an unknown quantity at this point
Yeah, I'd say as much as possible teams should strive to make their robots be able to launch any kind of minibot that can fit in the 12x12x12 inch dimensions.
Unread 01-08-2011, 04:16 PM
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
I feel like having a platform like this is the simplest and most practical option. It's really easy to just have a flat surface on top of your robot.
Unread 01-08-2011, 05:20 PM
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
caffel is an unknown quantity at this point
Good idea.
I suggest that we need to decompose the problem and at least describe these requirements:
1. envelope/modular shape for the MB.
2. delivery platform & temporary fastening approach (so MB stays put until it is deployed). Maybe the platform even includes a box which is just larger than the size of item 1.
3. execution: e.g. platform extends, then a 'pusher' slides the MB forward onto the pole and retracts.
4. MB recognizes contact w pole and starts up on its own.
Or ...
Platform extends fwd, latches a very small piece of FTC legal metal to the pole (minimalist Minibot) and spring launches the MB up the pole.
Charlie Affel,
Mentor 423
Unread 01-08-2011, 07:32 PM
remulasce remulasce is offline
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
This is a lot easier than it seems. Remember, the mini bot already uses a standard part system- FTC. All you need to do is drill FTC style holes all over a plate of metal. Then, before a match, determine where you want to connect mini and host bots on the plate, and put a bolt or shaft facing straight up at that point, with no nut holding the mini down. It is simply to prevent side-to-side movement. The mini is responsible for sensing that it is connected to the tower, at which point it must pull itself straight up, cleanly off the shaft/bolts. The host bot must extend the plate, with the mini bot, to the tower. No wiring or detach systems necessary.
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
Unread 01-08-2011, 07:58 PM
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
There was a similar idea to this last year to have a standard position for a suspension bar. As it was a great idea, it never worked because teams all went on their own plan.
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 01-08-2011, 08:02 PM
DonRotolo's Avatar
Back to humble
FRC #0832
Don't wait fror FIRST to develop anything like this. It is up to teams.
Also don't wait for FIRST Robotics Team xxxx (or xxx or xx) to develop it - you're just as good. Just do it, everyone will comment, we'll come to a consensus....done.
Waiting for 'someone else' to do it is the wrong idea.
Unread 01-08-2011, 10:59 PM
This is a great reason to try again. What went wrong last year? What should we do different this year to get the standard defined clearly and adopted? Maybe a catchy name and logo would help (think about Wi-Fi, Bluetooth, HDMI, USB...)?
One idea already mentioned in this thread that I liked:
Compile a list of teams that commit to implementing the standard. When you get to the regional, you'll know what pits to visit for compatible minibots / hostbots.
