Go to Post Spoiler: There will be no plasma cutters available in FIRST Choice - Jibsy [more]
Unread 08-01-2011, 13:24
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Unplaced ubertubes
What we do with ubertubes between autonomous and teleop. We can't hang ubertubes during teleop (<G16>), but we also MUST start the game in contact with an ubertube.
So what do you do with it if you don't place it during autonomous?
Team 2052- Knightkrawler
Mentor and volunteer
Unread 08-01-2011, 13:30
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Unplaced ubertubes
Currently the answer is unlisted in the manual. It would be a good question to post to the official Q&A Boards when opened.
-Michael Dessingue
Unread 08-01-2011, 13:38
huberje's Avatar
huberje huberje is offline
AKA: Jeffrey
FRC #0151 (Tough Techs)
huberje has a spectacular aura abouthuberje has a spectacular aura abouthuberje has a spectacular aura about
Originally Posted by Tanis View Post
We can't hang ubertubes during autonomous (<G16>)
This may have been a typo, but <G16> applies to the Teleoperated period.
AAnikstein AAnikstein is offline
AKA: Alex
FRC #0599 (Robodox)
AAnikstein is an unknown quantity at this point
Send a message via AIM to AAnikstein
As I understand it, you can place them during Autonomous...<G16> refers to during the Teleoperated period only, I believe, based on the heading of the subsection.
If you mean what happens in the Teleoperated period if you didn't place it during Autonomous...as far as I can tell, you pretty much might as well just drop it somewhere, since you can't do anything with it then.
Unread 08-01-2011, 13:42
Same thing you did with keepers in 2007: Drop them instantly. It might be to your advantage to have a "drop now" right at the end of automode, if you didn't have one before.
Unread 08-01-2011, 13:45
AKA: Bryan
Sorry about the teleop/autonomous typo confusion. Fixed it.
That's what I assumed. I'm just waiting for the matches in which there are 6 ubertubes littering the ground.
Unread 08-01-2011, 20:22
Jimmy K's Avatar
Jimmy K Jimmy K is offline
FRC #1002 (Circuit Runners)
Jimmy K is an unknown quantity at this point
At Peachtree in 2007, occasionally a keeper was "in danger of scoring" (i.e. on the spider-leg, but not fully supported by it) at the end of autonomous. When this happened, the head ref would stop the game, walk out onto the field, free the keeper from the robot's arm (popping it if needed), walk off the field, and then start teleoperated. This was not done if the keeper was not "in danger of scoring". I don't know if the refs will do that this year.
Unread 08-01-2011, 20:50
SashaKuznetsov's Avatar
SashaKuznetsov SashaKuznetsov is offline
FIRST Team 1279 Member
AKA: Alex Smith
FRC #1279 (Cold Fusion)
SashaKuznetsov is an unknown quantity at this point
What you do is you drop the ubertube when in teleoperated mode... In the way of the opposing teams.
Cold Fusion-Come chill with us
Unread 08-01-2011, 20:53
GaryVoshol's Avatar
Cogito ergo arbitro
There is no prohibition against carrying ubertubes during teleop; you just can't score them then.
In 2007 there was a specific provision in the rules to remove keepers. I didn't see anything like that in this year's rules. In fact, I suspect that there will not be a pause between auton and teleop.
(since 2004)
Unread 09-01-2011, 00:51
princessnatalie's Avatar
princessnatalie princessnatalie is offline
AKA: Natalie
FRC #2471 (Team Mean Machine)
princessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud of
You can carry them, but since they are game pieces you cant carry anything else while doing so;
GAME PIECES – the TRIANGLE, CIRCLE, SQUARE and UBERTUBE.
HERDING – controlling the movement of a GAME PIECE. A GAME PIECE shall be considered HERDED if it is in contact with the floor and, as the ROBOT moves in the direction of the GAME PIECE, the GAME PIECE is pushed in the same direction in a controlled manner, but does not remain in the position relative to the ROBOT if the ROBOT changes direction or orientation.
<G34> ROBOTS or HOSTBOTS may only POSSESS or HERD one GAME PIECE at a time.
Seattle Cascade Regional Champions
thanks 2046 and 492
Autodesk Oregon Regional
2011 Seattle Cascade Regional Champions
thanks 1510 & 2660
2011 Autodesk Oregon Regional Champions
thanks 360 & 3711
Unread 09-01-2011, 07:11
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
I disagree, I feel this will come up in Q&A and probably a revision but I think that a rule similar to the one in 2007 will be added to the manual and a break will be necessary for a situation where an UBERTUBE in on a SCORING PEG but nor fully supported by it, i.e. also still contacting the robot. In 2007, these tubes were considered to be "in danger of scoring". See an above post for an explanation.
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 11-01-2011, 13:59
johnnyburns35's Avatar
johnnyburns35 johnnyburns35 is offline
FRC #2487 (mechanical animals)
johnnyburns35 is an unknown quantity at this point
what if you dont have a arma nd your toching the tube at start of game play but is on the ground is it still dead?
Team 2487 sayville high school Mechanical animals
Our team Facebook page please like it! thanks
https://www.facebook.com/pages/Sayvi...54146258036097
Unread 11-01-2011, 14:20
Team 2811's Avatar
Team 2811 Team 2811 is offline
WHAT DID YOU DO!? ..umm... whoops!
AKA: Ian Heffron
FRC #2811 (Stormbots)
Team Role: Electrical
Team 2811 is on a distinguished road
If you just decide to have your robot hang the ubertube instead of staying still then there should never be 6 left on the playing field.
Its about a day out!
Once, there were two marshmallows roasting over a campfire.
First marshmallow, "It is really hot up here."
Second marshmallow, "OH MY GOD ITS A TALKING MARSHMALLOW!!!"
The more you learn the more you know
The more you know the more you forget
The more you forget the less you know
So why learn?
Unread 11-01-2011, 14:22
I don't understand the question. What does "dead" mean here?
Unread 11-01-2011, 14:24
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
There are strategic locations around the field where a well-placed ubertube could yield a great advantage.
Hi!
