Go to Post The Questions is, do we attempt to build a Mr.Fusion, or do we go for the Plutonium from the Libyans? - dag0620 [more]
Unread 08-01-2011, 13:33
team1631's Avatar
team1631 team1631 is offline
FRC #1631 (Rockin Robots)
team1631 is an unknown quantity at this point
More than one minibot on robot
I could not find a limit on the number of minbots a robot can carry. I was thinking if the weight allowed could you put a backup minibot on the robot.
Unread 08-01-2011, 13:44
angelawence11's Avatar
angelawence11 angelawence11 is offline
FRC #0195 (Cyber Knights)
Team Role: CAD
angelawence11 is an unknown quantity at this point
Re: More than one minibot on robot
I think that would be fine, but you can only actually deploy one (i think)
Unread 08-01-2011, 13:49
Definitely one for Q&A.
However: most references to the minibot are singular definite (the minibot), and you only get 10 seconds to deploy and run one. It's highly unlikely that you could deploy 2 in the same match. Common sense says that you will probably only want one on the robot (and at least one backup in the pit or on a different robot).
Unread 08-01-2011, 13:56
RandAlThor RandAlThor is offline
FRC #0115
RandAlThor is an unknown quantity at this point
Maybe you could deploy a minibot on each of your alliance's posts if the other teams don't have minibots
Unread 08-01-2011, 14:05
In 10 seconds?
The time makes it very difficult to do. Deploy (you've already lined up), cross, line up, deploy, and assume defense slows you down during the crossing (because messing with a robot contacting a base is an automatic DQ). Can the second minibot make it up before the score won't be counted?
Question for Q&A: Given the many last-second minibot deployments, will a minibot that reaches the top after the buzzer still count? Personally, I'd go with "yes" (<G68>), up until 10 seconds (same rule). That makes the chance of 2 much more feasible, but then you have to worry about legality of 2 minibots.
Unread 08-01-2011, 14:11
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I assume you can try shooting it all the way across the field and hope they hook on. Kinda like a Hail Mary pass. You just need to make your bot very accurate and very rugged.
Unread 08-01-2011, 14:29
Captain Cox Captain Cox is offline
Safety Captain & Head of Machining
FRC #0004 (ELEMENT)
Captain Cox is an unknown quantity at this point
Cool Re: More than one minibot on robot
I like the optimism of your idea, but you have to deploy the robot at the base of the post.
Unread 08-01-2011, 17:02
web_master_dpep's Avatar
web_master_dpep web_master_dpep is offline
"What you do, is who you are"
AKA: Dustin Pepper
FRC #0066 (Flyers)
Team Role: Webmaster
web_master_dpep is an unknown quantity at this point
Send a message via AIM to web_master_dpep Send a message via Yahoo to web_master_dpep
When looking at scoring it talks about a fourth bot on a pole being worth 10 points. That would imply, at least to me, that you could infact deploy two, if you had the time.
ŴΣß ΜăşťΣΓ đÞΣÞÞ
Unread 08-01-2011, 17:09
GaryVoshol's Avatar
Cogito ergo arbitro
That's the minibot that gets to the top of a pole fourth - lost the race.
(since 2004)
Unread 08-01-2011, 17:15
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Originally Posted by torihoelscher View Post
We are only allowed one on the robot. They cannot be past 15 pounds adding more than one will make the robot really heavy. My team was thinking the same thing but we are only allowed one. We are allowed to make more than one but we cannot have more than one on the robot.
Tori
Is there a rule that states this?
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 08-01-2011, 17:16
Waffles's Avatar
Waffles Waffles is offline
Ship it!
AKA: Crystal Vongnaphone
FRC #1511 (Rolling Thunder)
Waffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant future
Send a message via AIM to Waffles Send a message via MSN to Waffles
Tori
Sorry, can you reference a rule point from the manual? I mean, it's still good for Q&A otherwise XD
Thanks
Crystal Vongnaphone ... aka WAFFLES!
2010 Boston Regional Dean's List Finalist
FIRST Team 1511 Rolling Thunder
| Alumni | Leadership | Electrical | Media
Are you a Dean's list Finalist? Join our group!
Get the latest updates & important information on itsthedeanslist!
Unread 08-01-2011, 17:18
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Are you referring to <G67>? That states that the 4th robot to trigger the target earns 10 points. It has nothing to do with number of robots on poles
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 08-01-2011, 17:20
GaryVoshol's Avatar
Cogito ergo arbitro
And I found this definition:
HOSTBOT – the electromechanical assembly used to carry the MINIBOT. (ROBOT – MINIBOT = HOSTBOT). If a TEAM plays a MATCH without a MINIBOT, then the HOSTBOT is the ROBOT.
If you subtract a MINIBOT from the ROBOT, what's left is a HOSTBOT. So any "second minibot" would become part of that HOSTBOT.
I imagine the GDC thought they specified one MINIBOT; there will probably be a clarification.
(since 2004)
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Not really at the base. The deployment line is 18 inches above the base of the large part of the tower, which means it is a total of 30 inches above the floor. For it to be optimal, you would deploy it as fast and as high as possible to it gets to the top the fastest.
Unread 08-01-2011, 17:22
AKA: Kara Bakowski
We found it inside the manual. Unsure where. My whole team was talking about this.
Then we're going to have to take it as unknown unless a specific rule is cited, unfortunately :/ (not that we don't trust you - it's just that in a competition where the written rules are non-negotiable, our rule has to be "Cite a rule or it didn't happen")
Kara Bakowski
WMWBS '10 '11
