Go to Post If you want to use the don't ask, don't tell logic about asking then you know it is wrong. - Steve W [more]
Unread 08-01-2011, 14:32
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
<G19>
After DEPLOYMENT, MINIBOTS must remain completely autonomous.
Violation: The TOWER on which the MINIBOT is DEPLOYED is diabled. If the MINIBOT is
not deployed on a TOWER, then the ALLIANCE’s TOWER upon which the highest RACE
SCORE was earned will be discounted.
Typo in this rule. Also, this thread is now about typos that don't change the meaning of the rule, but should be corrected to stop people from getting around said rule.
Unread 08-01-2011, 17:58
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: <G19>
Can someone please explain G19 to me.
If I choose that my end game is better spent scoring tubes rather then deplying my mini-robot, why would the highest race score be discounted?
I believe I am reading this wrong, can someone please correct me.
P.S. I searched.
- Arizona North
Unread 08-01-2011, 18:04
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: <G19>
P.S. I searched.
If you spend your end game scoring tubes, then you have not violated the "Minibot must be autonomous" rule. I think the issue is that you are reading the "penalty" portion of the rule that is listed after the word "violation" as part of the rule.
Unread 08-01-2011, 18:06
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
Re: <G19>
P.S. I searched.
The highest racing score would be discounted if it was on a tower where a violation involving a mini bot occured. They could not discount the highest score if a team chose not to put out a mini bot becuase some teams may not try and use the mini bot. Hope that helps any questions just ask
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 08-01-2011, 18:07
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: <G19>
The way I read it is that if your mini bot is not fully auton, then either the tower its on is nixed, or if you didn't get it on a tower, one of your alliances towers is killed instead.
AKA be full auton mini bot or lose a lot of points <- the important part
KK4KQO
http://voltair.us
AKA: Alex Tannahill
Re: <G19>
I am still a bit confused.
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference during the END GAME. (Related form, DEPLOY, verb)
According to that there is no way to not deploy a minibot on the tower. The only thing I can think of is if you delpy the robot and it then leaves the tower.
I'm still scratching my head.
- Arizona North
Unread 08-01-2011, 18:08
AKA: Simon Bohn
Re: <G19>
It's a rule that should be split into two. What they are saying is that if you use your minibot for something other than climbing the tower, then they will disable whomever on your team got the highest score in the race.
Unread 08-01-2011, 18:11
Cuog's Avatar
AKA: Alex
FRC #0422
Re: <G19>
Not quite, its a specific penalty for having a mini bot that is not fully autonomous after deployment.
That penalty being either the points your mini bot scored being rejected, or the rejection of points scored by your alliance
KK4KQO
http://voltair.us
Unread 08-01-2011, 18:13
AKA: Simon Bohn
Re: <G19>
Whoops got that rule mixed up, ignore my above post.
Unread 08-01-2011, 18:14
AKA: carroll
Re: <G19>
only if you decide to deploy the minibot does this rule apply what the others are saying about how the tower is shut off if you dont deploy a fully auton minibot wouldnt apply to you if you didnt deploy a minibot at all.
Unread 08-01-2011, 18:22
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
Re: <G19>
There is no rule saying you HAVE to have a minibot. You are not compelled to visit the tower base or have a minibot in ANY way.
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 08-01-2011, 18:33
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
Re: <G19>
I think the intent of this rule is that people don't attempt to deploy mini-bots anywhere other than on the tower. That was at least the way i read it.
Team RUSH Alumnus and Mentor, Mechanical Engineer
Unread 08-01-2011, 18:40
Mike Ounsworth's Avatar
Mike Ounsworth Mike Ounsworth is offline
Roboticist
FRC #3710 (Cyber Falcons)
Mike Ounsworth is a jewel in the roughMike Ounsworth is a jewel in the roughMike Ounsworth is a jewel in the rough
Re: <G19>
More-over there are only 4 towers, so only two robots per alliance are able to deploy a mini-bot. The third may want to carry one for ballast, but it will serve no functional purpose and won't go anywhere near a tower.
I am doing graduate work on autonomous aerial and underwater vehicles with McGill University's Mobile Robotics Lab.
I have been Lead Programming Mentor with Teams 296 and 3710, as well as Head Mentor for 2 years at 3710.
Unread 08-01-2011, 21:54
ChristopherBuck's Avatar
ChristopherBuck ChristopherBuck is offline
FRC #0612
ChristopherBuck is a jewel in the roughChristopherBuck is a jewel in the roughChristopherBuck is a jewel in the rough
Re: <G19>
<G02> Blue box refers to an "ALLiANCE" in the second line
Unread 08-01-2011, 23:17
FRC #0612
Re: <G19>
in <T26> list item 5-- "Do no include any form of enabled wireless electronic communication"
