Go to Post Each team should ask not what their alliance can do for them, but what they can do for their alliance. - [more]
Unread 08-01-2011, 14:57
winglerw28 winglerw28 is offline
FRC #1274
winglerw28 is an unknown quantity at this point
Require assistance for imaging Classmate 2GO Netbook (2011)
After about an hour of frustration, I am seeking help with the new USB key provided for the 2010 Netbook that images it. I booted from it and it formats my HD and then fails with the error 'arithmetic exceeded 32 bits'.
I then tried the 2010 restore key and it gives me the error that claims restoreds doesn't exist!
Please help!
Thank you very much,
William Wingler
Unread 08-01-2011, 17:38
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: Require assistance for imaging Classmate 2GO Netbook (2011)
IM also having trouble but i cant get even close to the progress that you are seeming to be at. How do we even start the reimage?
Unread 08-01-2011, 18:01
Sawyer Sawyer is offline
FRC #4066
Sawyer is an unknown quantity at this point
Please help!
William Wingler
I'm not exactly sure what the problem is, the 32-bit error normally only occurs if you have an incompatible 64-bit program on a 32-bit system, and that shouldn't be the case here.
As for this you must insert the usb in the classmate before you start it up, and then on start up the computer should boot into the reflashing process, it'll take a while so make sure you have your classmate plugged in =D. I hope that helped.
There should be a readme file on the memory stick that gives directions on how to boot from the stick and start the reimaging.
Unread 08-01-2011, 18:08
AKA: Garty
thanks to the both of you! Im going to try that idea right now!
Unread 08-01-2011, 18:15
AKA: Garty
When i try to put the new image on the classmate, The junk drive doesnt light up is this a problem?
Unread 08-01-2011, 18:27
Da Kid's Avatar
Da Kid Da Kid is offline
FRC #2957
Da Kid is an unknown quantity at this point
Could someone please post a link to the readme.txt file that is supposed to be in the flashdrive with the new image on it?
Unread 08-01-2011, 18:58
2829ron 2829ron is offline
FRC #2829
2829ron will become famous soon enough2829ron will become famous soon enough
I find no file titled readme.txt. Can't find it. Here is the text from the file called HIDERECOVERY:
select disk 0
select volume 0
set ID=27 override
exit
Don't know if that helps. Imaging was a piece a cake for us. Maybe we got lucky.
David
Team #2829
Unread 08-01-2011, 19:06
See if this helps:
Instructions:
1. With the Classmate powered OFF, insert the bootable USB Key into an available USB port. Do not use a USB hub, plug the Key directly into the Classmate.
2. Power on the Classmate and when you see the 2Go PC screen, repeatedly press F11 until a small window appears entitled “Please Select Boot Device”.
3. Using the cursor keys, select the USB Key. It will likely be the second item in the list, beginning with USB:xxxx. Do not select the USB:Generic device, this is not your USB Key. If two identical looking USB items show up, don’t worry. Select the first of the two.
4. Press Enter and allow the Classmate to boot from the USB Key. Be patient, it can take a minute or more for wpeinit to finish.
5. Follow the on-screen instructions
Unread 08-01-2011, 21:10
Da Kid's Avatar
FRC #2957
Thanks! That worked for us.
Unread 08-01-2011, 23:14
FRC #1274
Ok, I've fixed one problem - the old restore disk was on a U3 drive and first set the .Bat to point to D: instead of F: (U3 adds a partition, and therefore all drives are a letter off after it.)
I liked the old rescueds system so I backed up my 2011 and used the files from 2010 and updated essentials, using the INSTALL.WIN file instead of the old version in 2010. I can format the HDD, but I still get an error trying to flash the .WIN to the drive. It's always the arithmetic error.
I get to the stage where I can follow onscreen instructions fine, wpeinit runs fine. It's when actually using the image. Perhaps I have a bad image? Can anyone link me to where I can download the 2011 flash drive contents?
Unread 11-01-2011, 00:02
darrellt darrellt is offline
FRC #2635
darrellt is an unknown quantity at this point
We succeeded in re-imaging the 2GO Netbook, but i keeps asking to to "Activate Windows"
We select "Activate now" and then "Active Windows online now" but then we get an Error Code 0x8007232B "DNS Name does not exist"
When I ping the DNS IP address, though, it responds.
Any ideas? Is there supposed to be a new code that we use to activate?
Unread 11-01-2011, 07:23
You need to install an additional Classmate update.
The Classmate needs to be connected to the Internet for Windows activation to complete.
Described in the setup directions How To Setup Your 2011 Driver Station.
All found on the Kit of Parts Website
Unread 11-01-2011, 10:52
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team#2057-Vegas can only hope to improve
if you go to start > search > system it says it will activate automatically in 3 days but you can activate it already.. im getting the same error as everyone else though if i press activate now.. this doesnt make sense.. anyone have a solution? I did the classmate updating of the batch file.. otherwise im just going to wait a few days and see what happens.
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 11-01-2011, 12:14
Team3337_mentor's Avatar
Team3337_mentor Team3337_mentor is offline
AKA: Amanda Salom
FRC #6659 (Cougar Robotics)
Team3337_mentor is an unknown quantity at this point
Thumbs up Re: Require assistance for imaging Classmate 2GO Netbook (2011)
Thank you very much Mark McLeod
I was going crazy trying to remember where I had seen the link to all of the configuration files.
Team 3337 Pathrobotics
Ms. Amanda Salom - Mentor
