Go to Post Our behavior – both good and bad – is contagious. Set a good example, behave in a mature, reasoned, professional manner and we will find that others around us will too. - dlavery [more]
Unread 08-01-2011, 14:47
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Where is WindRiver?
WindRiver wasn't included on the reimaging key this year, nor on the disk from NI. Where do we get the software? I'd check the KOP but our team hasn't inventoried it yet and I'd check the Control System page if not for the near-DDOS bringing the site to its knees.
Unread 08-01-2011, 15:11
Bethie42's Avatar
Bethie42 Bethie42 is offline
AKA: Bethany Carlson
FRC #0956 (Eagle Cybertechnology)
Bethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to behold
Re: Where is WindRiver?
We found ours [veteran team KOP] in the main tote. Check inside folders and so on. It is a white disk labeled Wind River, not bundled with LabVIEW.
Robot is now a verb.
We're back to square one...while we're at it, let's redesign square one!
Team 956: Celebrating ten years of FIRST!
Team record 2002-2011
2002: Highest Rookie Seed, AOR
2003, 2006, 2012: Xerox Creativity Award, AOR
2006: Semi-finalist, Sacramento Regional
2009: Quarter-finalist, AOR
2010: Quarter-finalist, AOR
2011: Semi-finalist, AOR, and Dean's List finalist, AOR
Personal record:
2008: Lead scout
2009: Lead scout, publicity
2010: Lead scout, publicity, fundraising, Chairman's, videography
2011: Team captain, lead programmer, fundraising, Chairman's, publicity, wrench-turning, Dean's List finalist at Autodesk Oregon Regional
Unread 08-01-2011, 17:22
MonkeyCookie MonkeyCookie is offline
FRC #3598
MonkeyCookie is an unknown quantity at this point
We ended up finding our Windriver DVD in the large white envelope labeled "Scholarship Info". It was sitting in there with the scholarship pamphlets.
Unread 08-01-2011, 18:57
Andrew T. Andrew T. is offline
FRC #1241
Andrew T. is an unknown quantity at this point
The Windriver CD is located in the Scholarship envelope.
Unread 08-01-2011, 21:54
I should have checked CD earlier
I found it in the Scholarship Information folder, thanks.
Unread 08-01-2011, 22:52
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Also check the WPILib project at http://firstforge.wpi.edu/sf/projects/wpilib for C++ support (as well as Java).
