Re: Peg height question?
For anybody that is interested, here's how I got those estimates I posted earlier:
Section 2 has a picture of the grids. The low one is about the height of the top of the diamond plate; the middle one is about the height of the team ID box. While not called out, from past experience I know the heights of both (3.5-4 ft and 6.5-7 ft respectively). I guessed that the high one would be about the same height above the middle as the middle was above the low one. |
These are unofficial measurements. This is what we got from measuring the mock-up at the Novi, MI local kickoff. I believe that these were measured from the floor to the middle of the peg.
Far right/left pegs: Bottom: 33in Middle: 69in Top: 106in Center pegs: Bottom: 40in Middle: 77in Top: 114in You can't build a precise robot off of those (since they're not official), but for planning purposes, they should be fine. When we can get to the official drawings, we will know for sure. |
Did this quickly so please check the numbers, but it looks pretty straight forward - the ends of the poles go all the way to the bottom of the tubing at the bottom.
From the field documents (ignoring the thickness of the sheet metal plate at the bottom, Floor to the center of the pegs: Outer poles Bottom peg 29.21 + .83 (half diameter) = 30.04 Center peg 58+8.17+.83 = 67 Top peg 58 + 45.17+.83 = 104 Middle pole 37.21 + .83 = 38.04 58 + 16.08 + .83 = 74.91 58 + 53.08 + .83 = 111.91 I used half of the 1.66 from the detail views, even though some of the BOM's say 1-1/2 pipe not 1-1/4 |
Special thanks to FIRST team 2502 for thinking ahead and uploading EVERYTHING onto their website! Here's the link:
http://team2502.com/uploads/rules/ |
According to page 6 the Arena section, on each column of scoring pegs, there is a 30 inch space from center to center. However, I have been unable to find the height of the bottom peg.
FIRST looks like they've rearranged their site, and seems to have taken down anything game related - probably in an attempt to kill some of their traffic. So at the moment, we're going to have to make designs based on some approximate lowest height, which appears to be around half the 30 inches between pegs (on the left and right, remember that the middle pegs are 8 inches higher). Hopefully they'll make the field drawings available soon. Alternatively, did anyone get them yesterday? EDIT: Quote:
Last edited by danderson : 09-01-2011 at 11:09. Reason: link requested was found |
Team 2502 has been able to snag up all information posted yesterday, and made it available on the link in my signature. I'd go by the approximations already made in the forum for now anyway, since I doubt anyone is ready to start sawing away.
#7
Just wondering, I can't read any of the game manual pdf besides the first page on my mac os x and this is after entering the password correctly
#9
So everyone knows there are 2 groups of 3 columns on each side. After looking over the game drawings and game manual, this is what it should be in each group of 3:
For the two on the left and right: Bottom peg: 29.21 inches (from bottom of floor to bottom of peg) Middle peg: 59.21 inches (from floor to peg bottom), aka 30 inches above bottom peg Top peg: 89.21 inches (from floor to peg), aka 30 inches above middle, aka 60 inches from bottom For the middle: Bottom peg: 37.21 inches (floor to peg) Middle: 67.21 inches (floor to peg), aka 30 inches from bottom Top: 97.21 inches (floor to peg), aka 30 inches from middle, aka 60 inches from bottom |
#10
5Time4For3Robots2to1Dance! |
#12
This whole situation is really odd. If you look in section 2 of the game manual, there's information and measurements on just about everything except the height of the pegs. Even things that really don't matter that much like the height of the guardrails. This leads me to believe that the exclusion of the peg heights was an oversight. Furthermore a few people have looked at the drawings and got different measurements. I think we should wait until tomorrow (Monday) when Q&A opens up and expect a revision to the manual shortly.
#13
Try the unencrypted ones at the team2502 site linked above. |
#14
In the Team Drawings, the heights are clearer.
I would assume these heights are the same as the ones on the actual field. They are rounded to the nearest inch. Middle Post
Side Posts
I calculated these heights by adding the lengths of the vertical sections and half the outside diameter of 1-1/4" Schedule 40 PVC to get the center point of the pipe. There is inaccuracy in that I am not sure how far the pipes go into the T-Fittings. Last edited by NickE : 09-01-2011 at 13:58. |
#15
Nick, did you account for the 1/8" base plate the pole sits on top of, an the 1/8" space between the poles when they join?
I did a quick and sloppy addition (and it could be wrong) and I got approximately 103.4 and 111.3 inches to the bottom of the two different top pegs. I could be wrong though. |
