Go to Post I don't think we should only be pointing at those with exceptional bots, but those that we consider a role model team in all aspects, not just in technical design - tribotec_ca88 [more]
Unread 08-01-2011, 16:40
earlybird's Avatar
earlybird earlybird is offline
They tried to ship me 2 competition
AKA: Robbie Oehrli
FRC #2849 (Team Ursa Major)
earlybird is a jewel in the roughearlybird is a jewel in the roughearlybird is a jewel in the rough
Re: Do minibots need to stay at the top of the pole?
Originally Posted by pacoliketaco View Post
based on the results of the GDC ruling on this, i foresee two possible outcomes: either a lot of broken polycarb plates from minibots running into them too quickly, or minibots exiting the arena after blasting through the scoring plate, if they dont need to remain in contact with them. one idea we had was to use springs to jettison something very light and more of just a mechanism than a "minibot" which would hit the plate.
Based on <R92> the only materials you could use to jettison something to the top are rubber bands or surgical tubing. So i think a sling shot type mechanism might be possible.
Unread 22-01-2011, 12:15
Darknight1243 Darknight1243 is offline
Darknight1243
AKA: David V.
FRC #3172 (SCRobotics)
Darknight1243 is an unknown quantity at this point
You cannot have any device with "Stored energy" in your mini bot, this does not include the battery, but eliminates springs and rubber bands and whatnot. This is what my mentor told me so I hope this helps.
Unread 22-01-2011, 20:26
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Rubber bands are on the allowed list of materials. However, slingshot-ing a robot up the pole is not allowed (Team Update 1).
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 24-01-2011, 09:41
Darknight,
That is an incorrect interpretation of the rule... Vertical motion on the minibot can come from the battery and motors only.
TU#1
<G19> After DEPLOYMENT, MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry).
The allowed parts list can be used for other things.
If the switches at the top of the post are in fact wired in series, activating any switch should trigger the response. It would be the way I would design/wire it to give the quickest response to minibot contact.
Unread 24-01-2011, 10:21
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Maybe. Another interpretation could be that DEPLOYMENT ends when the MINIBOT loses contact with the HOSTBOT. It's not defined in the rules.
This is in the rules...?
I read the definition of Deployment to mean that the "deployment" ends when you are no longer in contact with the minibot.
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference. DEPLOYMENT ends when the HOSTBOT is no longer in contact with the MINIBOT. (Related form, DEPLOY, verb)
<G19> MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry).
Thus G19 says you cannot transfer electric energy from your minibot battery into your motors until "deployment" is complete...."deployment" is not complete until you are no longer touching your minibot. We're spending quite a bit of time and energy making sure we are no longer touching minibot when the juice starts flowing......have I read too much into this?
Does G22 really mean that after you trip the switch, and your mini comes down, that it cannot touch your hostbot with incurring a penalty?
<G22> HOSTBOTS may not contact their ALLIANCE‟S MINIBOT once any part of it has climbed above the DEPLOYMENT LINE.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 24-01-2011, 10:51
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Suggest you shoot this one to Q and A asap! And share the outcome on CD for those who don't check the Q and A religiously...
