Go to Post Temp wiring is always bad but it is made worse when dealing with a $1000 part. You wouldn't try to lash a makeshift power source to your PC. - Al Skierkiewicz [more]
Unread 08-01-2011, 17:24
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Retroreflector Test
http://mmrambotics.ca/rambotics/retroreflector_test
We were quite excited with the results, the camera is a huge key to Logomotion this year.
Unread 08-01-2011, 17:26
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Retroreflector Test
Was this picture taken with or without flash from the camera?
Unread 08-01-2011, 17:27
Emily Horsman
With a decently bright flash (they call the BlackBerry Torch a Torch for a reason).
Unread 08-01-2011, 17:29
AKA: Matt B
FRC #1771 (1771)
Could you upload one without the camera flash?
Unread 08-01-2011, 17:47
Emily Horsman
Uploaded without camera flash, and another with flashlight.
Unread 08-01-2011, 17:51
AKA: Matt B
FRC #1771 (1771)
Cool, thanks.
Don't suppose you could get a picture from the Axis Camera looking at it?
Unread 08-01-2011, 17:53
Emily Horsman
I wish, it's at our school; will get picture ASAP.
Unread 08-01-2011, 17:58
AKA: Matt B
FRC #1771 (1771)
Hah, story of our life, right?
Thanks though!
Unread 08-01-2011, 19:24
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Thank GOD... They are really pushing autonomy this year, Laptops legal, making everything noticeable to the robot, the tape on the ground and a pretty simple game overall.
Thank you GDC
Unread 08-01-2011, 22:58
wazcodez's Avatar
wazcodez wazcodez is offline
AKA: Megh Suthar
FRC #2076 (Blackscots)
wazcodez is infamous around these partswazcodez is infamous around these parts
Send a message via MSN to wazcodez
Any idea of simple mechanism for robot during autonomous ...
i'm kinda lost ! How am i suppose to use this ... lol
" When you copy from one source it's called plagiarism when u copy from multiple it's Research .. ! " - Megh Suthar
Unread 08-01-2011, 23:00
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I first suggest tracking where the rack is. Than follow the tape to the right rack and then rack.
Unread 08-01-2011, 23:55
ChristopherBuck's Avatar
ChristopherBuck ChristopherBuck is offline
FRC #0612
ChristopherBuck is a jewel in the roughChristopherBuck is a jewel in the roughChristopherBuck is a jewel in the rough
Does it reflect in multiple directions? As in, if your camera is mounted near ground level (with or without supplemental lighting device, like a flashlight), and the tape is as high as the top row, will the camera be able to detect it?
Unread 09-01-2011, 00:16
Yes. That's kind of the point of being retroreflective. It sends light back in the same direction it came from.
Unread 09-01-2011, 02:45
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Very cool! I'm kinda uneasy about using the tape strips for autonomous, these don't seem to be a problem at all
How prone are these to being scratched/damaged/anything that would reduce reflectivity? I can only imagine how much damage our robots could do
On another semi-related note, does anyone with the field drawings know if either of the 2 tape strips on the pole itself are obstructed by a tube being on there?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
