Go to Post Semi-colon cancer -- the disease received after spending too much time writing lines of programming code - nehalita [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 08-01-2011, 13:52
TJ Cawley's Avatar
TJ Cawley TJ Cawley is offline
THE Freshman
FRC #1108 (Panther Robotics)
Team Role: Driver
TJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the rough
2011 Logomotion Mini Bots
what languages can the FTC robots be programmed in? LabView?
there is no FTC team in our area that we know of so i am tryin to find our option
"To create a world where science and technology are celebrated... Where young people dream of becoming science and technology heroes"-Dean Kamen
This should start each year by focusing on worldwide issues, and having a game that, in theory if not practice, will help fix or compromise a solution with those issues, to make a better, safer worldwide and FIRST community.
Unread 08-01-2011, 14:43
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
Re: 2011 Logomotion Mini Bots
I haven't done extensive research on the subject (and unfortunately the USFIRST website, which I assume would have the answer, is down), but if the setup is the same as regular VEX you have the options of RobotC, EasyC, or LabVIEW. This may be inaccurate, however.
I'm guessing that the following site will have the answer (when the server is back up): http://www.usfirst.org/roboticsprogr....aspx?id=18758
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 08-01-2011, 14:50
TJ Cawley's Avatar
THE Freshman
Team Role: Driver
thank you. do you have any experience programming the VEX bots with labview?
Unread 08-01-2011, 15:10
davidalln's Avatar
World's Worst Coder
AKA: David Allen
Actually, it looks like I was wrong. A quick Google says there is no easy way to use LabVIEW with VEX. It looks like your options are RobotC or EasyC, at least one of which I assume will be with the software.
ThePeracha's Avatar
ThePeracha ThePeracha is offline
FRC #1528
ThePeracha is an unknown quantity at this point
Is RobotC or EasyC based off of C/C++ or something? Does anyone have an example of a program source code in that language?
Unread 08-01-2011, 15:22
Bethie42's Avatar
Bethie42 Bethie42 is offline
AKA: Bethany Carlson
FRC #0956 (Eagle Cybertechnology)
Bethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to behold
From an FTC website: http://sites.google.com/site/ftciowacoaches/software
'The LEGO NXT bricks can run on one of three software programs: NXT-G, LabView or RobotC. However, to compete in an FTC competition, teams must use LabView or RobotC.'
I understand RobotC is text-based; NXT-G is a simple visual LabVIEW-type language but not allowed in FTC. Good Q for Wednesday: does the FTC programming rule apply, or can we program in NXT-G?
The Oregon FTC/FLL website ORTOP also has info. http://www.ortop.org/ftc/
Robot is now a verb.
We're back to square one...while we're at it, let's redesign square one!
Team 956: Celebrating ten years of FIRST!
Team record 2002-2011
2002: Highest Rookie Seed, AOR
2003, 2006, 2012: Xerox Creativity Award, AOR
2006: Semi-finalist, Sacramento Regional
2009: Quarter-finalist, AOR
2010: Quarter-finalist, AOR
2011: Semi-finalist, AOR, and Dean's List finalist, AOR
Personal record:
2008: Lead scout
2009: Lead scout, publicity
2010: Lead scout, publicity, fundraising, Chairman's, videography
2011: Team captain, lead programmer, fundraising, Chairman's, publicity, wrench-turning, Dean's List finalist at Autodesk Oregon Regional
Unread 08-01-2011, 16:00
cooldude8181's Avatar
cooldude8181 cooldude8181 is offline
AKA: Charlie Davies
FRC #1245 (Shazbots)
cooldude8181 is an unknown quantity at this point
Is there any real advantage to having code on the minibot?
Because everyone knows that code just ads excessive weight.
Would a bot that would just start when it knows the pole is there work better than something that the drivers would have to control?
Unread 08-01-2011, 16:31
TJ Cawley's Avatar
THE Freshman
Team Role: Driver
software, or code, has no weight. for any robot to move, it needs code. otherwise, to get it running would be direct control between motor wires and battery, which is illegal
Unread 08-01-2011, 17:38
ThePeracha's Avatar
FRC #1528
The minibots have to completely autonomous. Also, the video shows the base of the poles as a obstacle to be overcome. Unless your minibot can somehow climb the base, it'll have to directly planted from the robot onto the pole and begin climbing.
Unread 08-01-2011, 17:57
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Are you sure? Why couldn't one simply leave it running forward, until it hits a switch, then drive in reverse? (Assuming they don't have to stay at the top)
Unread 08-01-2011, 19:55
TJ Cawley's Avatar
THE Freshman
Team Role: Driver
that would take code. we do not have self programmed parts available to this competition. no code, no movement.
plus, that means your minibot would be running the entire autonomous and teleop match, leaving no battery life left
Unread 08-01-2011, 20:06
DonRotolo's Avatar
Back to humble
FRC #0832
Can you cite the specific rule that forbids this please?
Unread 08-01-2011, 20:11
TJ Cawley's Avatar
THE Freshman
Team Role: Driver
I could not find a specific rule on this, so it MAY be legal, but if your minibot runs the entire match, you have no power when you need it to climb the last 10 seconds
Unread 08-01-2011, 20:23
pfosx's Avatar
pfosx pfosx is offline
AKA: Paul Fossenier
FRC #3161 (Tronic Titans)
pfosx is an unknown quantity at this point
the game manuel seems to be alittle on the vague side towards these minibots. how do we control them!
The FTC mini-kit from FIRST Choice, does that include 'everything' to make a minibot? If we use an NXT with this 'mini-kit', is it a functioning minibot?
Dean's List Finalist Award - WAT 2011
Unread 08-01-2011, 20:29
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
not necessarily, you could have a three way switch that connects the battery directly to the motor forward, backwards, and off, and the main robot could turn it on, deploy it, it would hit the top, flipping the switch, sending it in reverse. No wasted battery, no code
Watchdog.Kill();
