Go to Post The GDC has spoken, we have listened and will follow their ruling. - ChuckDickerson [more]
Unread 08-01-2011, 18:00
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Need help with reimaging!!!!!!
Hello im trying to reimage our classmate and every time i try to do it i come across a ERROR: PLEASE CONTACT THE CTL. or something like that anyone care to help?
Unread 08-01-2011, 18:51
2829ron 2829ron is offline
FRC #2829
2829ron will become famous soon enough2829ron will become famous soon enough
Re: Need help with reimaging!!!!!!
Hello,
I believe if you shut down the classmate, reboot it with the thumb drive plugged in, and press f12 (repeatedly if you like), than you will then be ready to image the computer. Select the USB drive and go from there. Hope this helps.
David
Team #2829
Unread 11-01-2011, 19:04
Mike9966's Avatar
Mike9966 Mike9966 is offline
Mentor Mike
FRC #2846 (Fire Bears)
Mike9966 is an unknown quantity at this point
Hi all, I'm having what might be the same problem, I don't know, but I get the same message.
I put the usb flash drive on the powered down class mate from 09, and turn it on, press F11, choose the flash drive to boot from, and after a few moments it asks if it's ok to format the HD, press enter.
IT then extracts many files and finally gets to trying to put file 3c314c.msi on and comes up with error 23, it tries again, fails, and says...
"error restoring image"
data error (cyclic redundancy check).
error please contact CTL for support
Press any key to continue...
Any ideas on this? I've tried this perhaps 5 times all with the same error. I'm beginning to wonder if I have a dud file on the flash drive?
Thanks for your thoughts and suggestions,
Mike
2846
Do the best you can! Always
Go FireBears
2009 10000 Lakes Finalists, thanks 2825 & 2177
2010 10000 Lakes quarter finalists
2011 Duluth and 10000 Lakes
2012 Superior, and 10K Lakes, Qt finals, MRI
2013 Northern lights, 10K Lakes-Semi finalists, MRI, River Rendezvous, Minne Mini
2014 Northern Lights, 10K Lakes
Unread 11-01-2011, 20:11
winglerw28 winglerw28 is offline
FRC #1274
winglerw28 is an unknown quantity at this point
Many people are having similar errors, including myself. My suggestion is to find an alternative laptop if you can for now. I feel like FIRST is going to need to send out an update for the flash drives and will need to ensure the images are not corrupt.
Unread 14-01-2011, 17:44
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
I am having a minor issue after re-imaging from the 2010 classmate. My driver account is not being automatically opened when I reboot the machine. Not a major issue, but is there a workaround?
Unread 14-01-2011, 18:47
They just aren't setup to auto-login anymore.
If you want it to do this:
  1. Login to the Developer account
  2. Start->All Programs->Accessories->Command Prompt
  3. In the popup window type: control userpasswords2
  4. Another popup (User Accounts)
  5. Click on the Driver account
  6. Unclick "Users must enter a user name and password to use this computer"
  7. Click OK
Unread 14-01-2011, 18:55
FRC #1094
Thank you
