Go to Post The term, bridge, is a beauty. - JaneYoung [more]
Unread 08-01-2011, 17:49
ThePeracha's Avatar
ThePeracha ThePeracha is offline
FRC #1528
ThePeracha is an unknown quantity at this point
Re: More than one minibot on robot
Originally Posted by Captain Cox View Post
I like the optimism of your idea, but you have to deploy the robot at the base of the post.
Are you positive? Where did you see that rule?
Unread 08-01-2011, 18:01
Waffles's Avatar
Waffles Waffles is offline
Ship it!
AKA: Crystal Vongnaphone
FRC #1511 (Rolling Thunder)
Waffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant future
Send a message via AIM to Waffles Send a message via MSN to Waffles
It's not necessarily the BASE. When you "deploy":
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference during the END GAME. (Related form, DEPLOY, verb)
DEPLOYMENT LINE – located on the POST, approximately 18 inches above the top surface of the BASE.
These are the Manual definitions.
I believe you have an 18" buffer zone on which you PLACE the minibot.
(Otherwise, correct me if I'm wrong)
Crystal Vongnaphone ... aka WAFFLES!
2010 Boston Regional Dean's List Finalist
FIRST Team 1511 Rolling Thunder
| Alumni | Leadership | Electrical | Media
Are you a Dean's list Finalist? Join our group!
Get the latest updates & important information on itsthedeanslist!
Unread 08-01-2011, 18:04
ThePeracha's Avatar
FRC #1528
Can it be thrown above the line?
Unread 08-01-2011, 18:06
Waffles's Avatar
Ship it!
If you do it above the line, it must be during the End game period I think?
I'm not absolutely POSITIVE though.
Unread 08-01-2011, 18:09
goldenglove002 goldenglove002 is offline
AKA: Alex Epstein
FRC #1311 (Kell Robotics)
goldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the rough
This was one of my first thoughts when they were talking about sharing minibots. I definitely think it's possible to do, though very difficult.
After perusing through the manual it is definitely a question for Q&A.
Wording seems to imply the use of one bot, but never says anything definite against having two.
Unread 08-01-2011, 18:11
web_master_dpep's Avatar
web_master_dpep web_master_dpep is offline
"What you do, is who you are"
AKA: Dustin Pepper
FRC #0066 (Flyers)
Team Role: Webmaster
web_master_dpep is an unknown quantity at this point
Send a message via AIM to web_master_dpep Send a message via Yahoo to web_master_dpep
Originally Posted by Radical Pi View Post
Are you referring to <G67>? That states that the 4th robot to trigger the target earns 10 points. It has nothing to do with number of robots on poles
Misread that part thanks for the correction. Read it before I had time to get a little sleep.
ŴΣß ΜăşťΣΓ đÞΣÞÞ
Unread 08-01-2011, 18:25
EricH EricH is online now
For those talking about throwing:
Read the definition of Deployment and all of Game Section 3.1.5 regarding where you can deploy a minibot. Then read the safety rules.
You cannot deploy above the line.
Unread 10-01-2011, 18:17
1631JD 1631JD is offline
Psychotron
AKA: Jordan
FRC #1631 (Rockin' Robots)
Team Role: Tactician
1631JD is an unknown quantity at this point
Its more like having two so that we can deploy on either side and do not have to waste time making sure the ROBOT is on the correct side for DEPLOYMENT. It is not for an attempt to deploy two in a single match.
Unread 10-01-2011, 21:32
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
I suspect this will get clarified tomorrow, but I feel that the answer is obvious as it is.
Originally Posted by Game manual, page 11
The ROBOT includes both the HOSTBOT and the MINIBOT (ROBOT = HOSTBOT + MINIBOT).
As said before, "MINIBOT" is singular, meaning that if you have two, one of them is part of the HOSTBOT. It doesn't matter if you have two identical devices, one of them is a MINIBOT (and therefore excluded from the HOSTBOT size/weight rules) and the other is not. The latter device (which I'll call the NOTBOT) must be weighed with the HOSTBOT and fit the size constraints with the HOSTBOT. If you deploy the NOTBOT, you've broken <G42>. You can't argue that whichever one you deploy is the MINIBOT and the other is the NOTBOT, because at inspection, one of them was part of the HOSTBOT, and one was the MINIBOT. Changing this is a violation of <R88>.
Based on <R10> and the definition of ROBOT, it seems safe to say, "Each team can enter ONE (1) HOSTBOT plus ONE (1) MINIBOT into the 2011 FRC."
Having multiple minibots is a clever and fun idea, but I can't see how the rules allow this.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 10-01-2011, 22:27
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
If we find out via Q&A that each team is only allowed one minibot on the hostbot, something that you might want to consider is having a deployment mechanism that can deploy in either direction. It might be mechanically tougher, but it is do-able (maybe a small turret of some kind would do the trick).
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 11-01-2011, 01:10
Psychotron
AKA: Jordan
Most likely though a turret would interfere with the arm and couldn't have full rotational capabilities.
Unread 11-01-2011, 01:14
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Even if you can have 2 bots, why waste the space and weight?
Unread 11-01-2011, 01:59
Why not put the arm on the turret? Now you can grab tubes off whatever side of the robot is handiest, and launch the minibot on whatever side is handiest--and the minibot may act as a partial counterweight to the arm if you do it right.
Full rotational capabilities are tougher--run your wires/tubing up the middle with room to twist a bit, and I think you could do it without a problem. Running up/around the side will give you headaches.
Unread 11-01-2011, 12:18
Psychotron
AKA: Jordan
Well we are already going to build at least two minibots for the coopertition points, and if it provides beneficial to have two then why not do it?
Thanks. We'll see if it will work, though the only problem could be accidental damage to the arm. That is the risk though in competitions like this so I guess its no big deal.
Unread 11-01-2011, 14:19
Jared Russell's Avatar
Taking a year (mostly) off
I guess nobody thinks it's within the realm of possibility that a minibot might fall off the pole or otherwise fail to reach the top?
In such a situation, being allowed to carry a second minibot could mean the difference between getting at least 10 bonus points (and possibly more if there are some towers that are unoccupied) vs. none at all.
That said, I agree that the rules seem to refer to the minibot as a singular entity.
