Re: Require assistance for imaging Classmate 2GO Netbook (2011)
When i try to put the new image on the classmate, The junk drive doesnt light up is this a problem?
Could someone please post a link to the readme.txt file that is supposed to be in the flashdrive with the new image on it?
select disk 0 select volume 0 set ID=27 override exit Don't know if that helps. Imaging was a piece a cake for us. Maybe we got lucky. David Team #2829 |
See if this helps:
Instructions: 1. With the Classmate powered OFF, insert the bootable USB Key into an available USB port. Do not use a USB hub, plug the Key directly into the Classmate. 2. Power on the Classmate and when you see the 2Go PC screen, repeatedly press F11 until a small window appears entitled “Please Select Boot Device”. 3. Using the cursor keys, select the USB Key. It will likely be the second item in the list, beginning with USB:xxxx. Do not select the USB:Generic device, this is not your USB Key. If two identical looking USB items show up, don’t worry. Select the first of the two. 4. Press Enter and allow the Classmate to boot from the USB Key. Be patient, it can take a minute or more for wpeinit to finish. 5. Follow the on-screen instructions Last edited by Mark McLeod : 08-01-2011 at 19:08. |
Thanks! That worked for us.
Ok, I've fixed one problem - the old restore disk was on a U3 drive and first set the .Bat to point to D: instead of F: (U3 adds a partition, and therefore all drives are a letter off after it.)
I liked the old rescueds system so I backed up my 2011 and used the files from 2010 and updated essentials, using the INSTALL.WIN file instead of the old version in 2010. I can format the HDD, but I still get an error trying to flash the .WIN to the drive. It's always the arithmetic error. I get to the stage where I can follow onscreen instructions fine, wpeinit runs fine. It's when actually using the image. Perhaps I have a bad image? Can anyone link me to where I can download the 2011 flash drive contents? |
#7
We succeeded in re-imaging the 2GO Netbook, but i keeps asking to to "Activate Windows"
We select "Activate now" and then "Active Windows online now" but then we get an Error Code 0x8007232B "DNS Name does not exist" When I ping the DNS IP address, though, it responds. Any ideas? Is there supposed to be a new code that we use to activate? |
#8
You need to install an additional Classmate update.
The Classmate needs to be connected to the Internet for Windows activation to complete. Described in the setup directions How To Setup Your 2011 Driver Station. All found on the Kit of Parts Website Last edited by Mark McLeod : 11-01-2011 at 10:57. |
#9
if you go to start > search > system it says it will activate automatically in 3 days but you can activate it already.. im getting the same error as everyone else though if i press activate now.. this doesnt make sense.. anyone have a solution? I did the classmate updating of the batch file.. otherwise im just going to wait a few days and see what happens.
#10
Thank you very much Mark McLeod
I was going crazy trying to remember where I had seen the link to all of the configuration files. Team 3337 Pathrobotics Ms. Amanda Salom - Mentor |
#11
I'm having a problem in the reimaging process, too. After the disk is reimaged, and a success message is displayed, the classmate crashes while trying to boot windows. We restarted the classmate and started it in safe mode, but there was a boot hangup at "CLASSPNP.sys" and the classmate subsequently crashed. We've tried to reimage the classmate a number of times, but this happens every time.
Many thanks in advance!! |
#12
I still have not been able to get a working image at all so I, in my infinite frustrations, gave the classmate to another team member to play with.
It has been replaced by an IBM Thinkpad R40, which is quite sluggish being a P4 2.2GHz with 512mb of RAM. It is still better then the small and low-powered classmate. I just need to be able to program in LabView. If anyone figures out solutions to these problems, please let me know, it would be immensely appreciated. Thank you very much, Will |
