Go to Post And, if you don't know what something means, say so, we'll be happy to explain. - DonRotolo [more]
Unread 08-01-2011, 18:14
Mike Ounsworth's Avatar
Mike Ounsworth Mike Ounsworth is offline
Roboticist
FRC #3710 (Cyber Falcons)
Mike Ounsworth is a jewel in the roughMike Ounsworth is a jewel in the roughMike Ounsworth is a jewel in the rough
Re: Springs on a minibot?
Originally Posted by ThePeracha View Post
Excellent idea. But won't the magnets disrupt both the sensors and the electronics on the minibot?
Who says the mini-bot needs electronics?
What if your mini-bot was a passive cylinder that wraps around the pole and is then launched from a HOST-mounted "crossbow" (or other stored-energy launcher). I get the feeling this isn't in the spirit of the mini-bot, but I don't see anything in the rules specifically forbidding it.
I am doing graduate work on autonomous aerial and underwater vehicles with McGill University's Mobile Robotics Lab.
I have been Lead Programming Mentor with Teams 296 and 3710, as well as Head Mentor for 2 years at 3710.
Unread 08-01-2011, 18:18
ThePeracha's Avatar
ThePeracha ThePeracha is offline
FRC #1528
ThePeracha is an unknown quantity at this point
Originally Posted by nighterfighter View Post
I feel like using magnets would only slow you down.
Size =/= power. A small and light magnet can easily be very powerful. However, a magnet powerful enough to latch a 15 lb bot onto a pole would probably disrupt the sensors on the pole and also the electronics on the minibot as well.
Unread 08-01-2011, 18:20
ThePeracha's Avatar
FRC #1528
Interesting. However, I see a few problems. If the magnet is powerful enough to attach a minibot onto the pole, won't the electronics be disrupted on the hostbot and the sensors on the pole?
Unread 08-01-2011, 18:23
salman1992 salman1992 is offline
FRC #1601
salman1992 is an unknown quantity at this point
<G46> MINIBOTS may only be used to climb the TOWER.
I don't know if launching would be allowed.
Unread 08-01-2011, 18:42
AntonOlsen AntonOlsen is offline
AntonOlsen will become famous soon enoughAntonOlsen will become famous soon enough
The magnets will not affect the electronics or sensors in any way unless you are using magnetic reed switches or hall effect sensors.
I've build a few VEX bots that use magnets to climb steel walls and I-Beams and never had a problem with the sensors, electronics, or radios.
Mustangs's Avatar
Mustangs Mustangs is offline
AKA: Lawrence Schofield
FRC #3571 (Mustang Robotics)
Mustangs is an unknown quantity at this point
Exclamation Re: Springs on a minibot?
what if you were to us some sort of rounded magnet attached to a drive motor with another two round magnets, all on seperate axles, so that they are in a triangle shape, would the magnet on the drive motor be able to push that up? or would u need too powerful a motor to be able to go up the pole fast enough?
Mustangs Robotics - Team 3571
Unread 08-01-2011, 18:43
Waffles's Avatar
Waffles Waffles is offline
Ship it!
AKA: Crystal Vongnaphone
FRC #1511 (Rolling Thunder)
Waffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant future
Send a message via AIM to Waffles Send a message via MSN to Waffles
Depends on how we interpret "climb".
Here's another thread on the same topic: http://www.chiefdelphi.com/forums/sh...threadid=88428
On the magnet note, that is a good point about affecting the surrounding electronics XD... forgot about that ~.~
Crystal Vongnaphone ... aka WAFFLES!
2010 Boston Regional Dean's List Finalist
FIRST Team 1511 Rolling Thunder
| Alumni | Leadership | Electrical | Media
Are you a Dean's list Finalist? Join our group!
Get the latest updates & important information on itsthedeanslist!
Unread 08-01-2011, 18:57
ThePeracha's Avatar
FRC #1528
Well, FTC and FRC parts are different, right? Just because the electronics in FTC aren't affected won't mean the electronics from FRC will also hold up.
GaryVoshol's Avatar
Cogito ergo arbitro
That limits what the MINIBOT can do - it's only function is to climb the tower. It doesn't say anything about how that climbing is accomplished.
(since 2004)
Unread 08-01-2011, 23:48
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Folks - Unlees you want to name specific piece of eqmt that is sensitive to magnetic fields, don't worry about their effect on 99.9% of "electronics". There won't be any effect.
Unread 09-01-2011, 04:44
Walker Walker is offline
FRC #1318
Walker is an unknown quantity at this point
Originally Posted by Duke461 View Post
also, that would be pretty hard because your minibot has to stay in contact with the pole throughout.
-Duke
Really? Where in the rules does it say this?
Unread 09-01-2011, 06:46
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
There has also been discussion about launching MINIBOTS here:
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 09-01-2011, 09:39
E F E F is offline
FRC #0365
E F is an unknown quantity at this point
A note to consider if using springs:
"Teams must be very careful when incorporating springs or other items to store energy on their ROBOT by means of part of material deformation. A ROBOT may be rejected at inspection if, in the judgment of the inspector, such items are unsafe." <R01> under 4.3.1
Unread 09-01-2011, 23:29
Furrah!! Furrah!! is offline
FRC #1425
Furrah!! is an unknown quantity at this point
Do you guys think that using springs for the purpose of clamping the minibot onto the pole would be legal?
Unread 10-01-2011, 13:37
GaryVoshol's Avatar
Cogito ergo arbitro
Are springs on the list of approved parts for the MINIBOT?
(since 2004)
