#14
Re: Minibot
The following items are the only permitted materials for use on the MINIBOTS:
A. TETRIX components, B. no more than two motors (PN W739083), C. exactly one 12V rechargeable NiMH battery pack identical to those supplied in the FTC kit of parts (PN W739057) D. No more than one HiTechnic DC motor controllers, E. No more than one NXT controller with the Bluetooth functionality disabled, F. Polycarbonate, G. Polycarbonate glue, H. Aluminum sheet, 90° angle, u-channel, tube, bar, I. rivets, J. non-metallic rope or cord, K. wire nuts, L. cable ties, M. limit switches, N. no more than two common household light switches, O. wire of appropriate gauge (see Rule <R40>), P. non-slip pad, Q. PVC or CPVC pipe, R. PVC cement or cleaner, S. Mechanical hardware (i.e. screws, bolts, etc) , T. Loctite or similar thread-locking product, U. Rubber bands, V. Surgical tubing, W. Electrical tape and shrink tubing, X. PWM extension cables, Y. Universal security clips to hold the PWM connectors together, Z. Hook and loop fastener (may not be used as tape), and AA. Magnets. |
