Go to Post You can learn a lot from making mistakes - even more from fixing them. - DarrinMunter [more]
Unread 08-01-2011, 20:39
Jogo Jogo is offline
FRC #0353 (Pobots)
Jogo is on a distinguished road
Communicating with Feeder
Any ideas for helping the feeder pick a shape? I imagine communication with the analyst across the field would be quite difficult.
How about an indicator on the robot that lights up Red, White, or Blue? Anyone have any experience with some sort of LED indicator (specifically in LabVIEW?)
Unread 08-01-2011, 20:51
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Communicating with Feeder
I had this idea while eating "inspirationBell" (Seriously, whenever I eat Taco Bell I get into philosophical/inventive convos or thoughts...)
2 ideas I got-
3 seperate LED clusters, (in shape of triangle,square,circle) controlled by 3 seperate spikes.
2 LEDs, allowing for 4 different "commands".
(Both off, one on one off, one off one on, both on)
Not sure if they make these, but a LED, where if given regular polarity (Set the Spike forward) one color, and if given reverse polarity, it is a different color. (Set relay reverse.) No color = off, or circle, for example.
Unread 08-01-2011, 20:57
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I would assume just the driver communicating with the feeder. Seems the lowest tech way to do it.
Unread 08-01-2011, 21:00
AKA: Matt B
FRC #1771 (1771)
Hard to do from across the field.
Unread 08-01-2011, 21:01
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
I will personally bake cookies for any team that utilizes semaphore to communicate with their feeder.
For those of you unfamiliar with semaphore, I would recommend checking out Monty Python's semaphore Wuthering Heights.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 08-01-2011, 21:02
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I highly suggest reading the manual thoroughly or you will have a very difficult and ultimately disappointing season.
The feeders for an alliance are located across the field from the drivers.
Unread 08-01-2011, 21:07
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Two options, run the circuits off of the digital sidecar if you have low milliamp requirements for your LEDs
Other option (I am not entirely sure if custom circuits on spikes are legal) but they are LEDs aka Light Emitting Diodes with Diodes being the key word
If you run - to anode and + to cathode it doesn't light up, so you have one wire come off the positive side of the spike, branch into two wires, one is connected to an anode of an LED the other to a cathode of another LED, continue connecting LEDs in the same direction (+-anode cathode-anode cathode-anode cathode-) and the opposite direction. Run the spike one way it turns on one set, the other way it turns on the other set.
While you generally have to apply high voltage reverse polarity to damage an LED, some are damaged more easily than others, in which case buy an actual diode that can handle the higher voltage reverse polarity and stuff that in there to avoid burning out your LEDs
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
AKA: Matt B
FRC #1771 (1771)
Isn't there a rule prohibiting coaches/human players/drivers from bringing stuff up to the driver station area?
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Well you could use stuff like that. But I would imagine if you get a good feeder they would be able to kind of realize which ones you would need. Just my little thought. (especially as the season progressed)
Unread 08-01-2011, 21:10
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
roughly 20 members of 461 went to Taco Bell to discuss the game tonight. I know what you mean, dude
Also I'm not too familiar with driver station rules, but would a drive coach be able to hold up a sign signifying red white or blue to the human player across the field?
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
AKA: Matt B
FRC #1771 (1771)
Originally Posted by Trent B View Post
(I cannot remember if LEDs can be damaged by reverse current)
I believe they can.
EDIT: After looking it up, it seems they can only be hurt if passed with a large enough voltage...
http://en.wikipedia.org/wiki/LED_circuit#Polarity
And dShad- A good human player MIGHT know what it looks like you need, but they won't be up to date with the coaches needs/other human player.
Unread 08-01-2011, 21:13
AKA: Bryan
This was my original thought as well. If you can get your feeder to know the game and your team's strategy as well as your coach (or analyst), then you should be good for the most part.
There will still be times that you want to stray slightly from the plan though, so it would be good to have some sort of system set up. LEDs might be a little overkill though.
Unread 08-01-2011, 21:15
AKA: Bryan
I believe they can.
Not easily. LEDs are diodes, which are designed to control the direction of the flow of electricity. More specifically, they only allow current to flow in one direction.
EDIT: Oops, double post. My apologies.
Unread 08-01-2011, 21:16
College Mentor
AKA: Trent Borman
I believe they can.
A little more looking into it it appears as long as you don't exceed the breakdown voltage (which is the voltage you have to reach before you can start to conduct in reverse), it shouldn't get damaged. Something to dig out the spec sheets for.
There is a point called the breakdown voltage where you can conduct backwards. It will vary from LED to LED
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Thank you for telling me that... IDK my idea goes down the tube
Big LCD screens on the robot that display a color
