Thread Tools |
Rating:
Display Modes |
Re: Classmate - Windows Not Activating
That's probably not going to help, because we can't even reach the activation server.
Edit: I just checked if my home computer is running on genuine windows, it works fine for me. May be it's your internet giving problems? Edit Edit: http://www.computing.net/answers/win...tes/89879.html Microsoft is most likely blocking your ping requests.. Last edited by PriyankP : 08-01-2011 at 21:48. |
I figured that with the ping requests. As for the verification, I was just wondering how many other people were having the problem and trying to provide as much info as I could to get the issue solved.
I just reimaged. First have you checked if all the drivers are installed after the reimage? lol mine weren't. second you should follow this instruction that was in the how to setup pdf. "Download the file “Classmate_Update.bat” from the 2011 FRC Control System website and copy it to the Desktop of the Classmate." It worked for me.
I reimaged the classmate to the 2011 image, installed the classmate update as per the instructions mentioned above, and then installed the driver station update. Sometime during that process the activation messages disappeared. If this doesn't work for you, let us know!
This is working just fine now, but we're low on disk space. I'm quite tempted to remove the recovery partition and add it to the Windows partition. Doing this over a net or USB-booted copy of linux should work alright.
EDIT: Yeah... netbooting is way too complex, and I don't have any flash drives large enough that I'm willing to wipe... any other ideas? Last edited by BrandonD-1528 : 10-01-2011 at 17:03. |
#7
Actually I lied that software update didn't do junk lol I'm getting that DNS error too. I've already imaged it like twice. I have 26 more days to activate haha but I can't because of the DNS error.
#8
FIRST knows about the activation issue and is working on the solution.
http://forums.usfirst.org/showthread.php?t=15994 |
#9
My email: Quote:
#10
Team 834 is still undergoing issues with Windows activation too, I thought I fixed the issue earlier by running the validation through http://www.microsoft.com/genuine/val...trol=i nstall
but now it appears that it just turned Windows into a 30 day trial. When we had 17 days left I attempted to rearm but on restart the trial went down to only 3 days... We now used all of the rearms possible, so any fix would be appreciated. Last edited by ParsonsProject9 : 22-01-2011 at 11:05. |
#11
