Go to Post The 48 defensive DNA lies dormant in the drive train. It's impossible to forget. - Koko Ed [more]
Unread 08-01-2011, 17:57
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Catapulting minibot
Assuming that this is possible to aim/trajectory correctly, is this legal:
Your robot is 30 inches tall (the exact height of the deployment line). Recessed in it, is the minibot, which is catapulted, with whatever method from the robot up to the height of 60 inches, and then continues to the top.
Is this legal?
The reason I ask this, is that I can't find any rule that states that it is not. Although "deploy" is clearly defined, it is never defined that a robot must deploy the minibot in the deployment zone.
<G20> ROBOTS/HOSTBOTS may not contact their own TOWERS above the DEPLOYMENT LINE.
Violation: PENALTY for contact. TOWER is disabled if MINIBOT is DEPLOYED above the
DEPLOYMENT LINE.
But does this mean deployed if it is not touching the robot when it touches the area above the line?
Unread 08-01-2011, 18:02
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Catapulting minibot
I really can't see this being legal. Its implied that the minibot is an extension of the main robot, and thus must be deployed below the deployment line
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 08-01-2011, 18:03
ATannahill ATannahill is offline
AKA: Alex Tannahill
From section 1
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference during the END GAME. (Related form, DEPLOY, verb).
- Arizona North
Unread 08-01-2011, 18:23
AKA: Simon Bohn
Just realized a way to get around that rule. Throw out a string, and detatch it at the bottom of the tower, THEN you catapult out the minibot.
Would that be against the rules?
Unread 08-01-2011, 18:30
GaryVoshol's Avatar
Cogito ergo arbitro
Is the string part of your HOSTBOT, or part of the MINIBOT?
If part of the HOSTBOT, then you haven't deployed the MINIBOT properly.
If part of the MINIBOT, then the MINIBOT is bigger than 12" ^3.
(since 2004)
Unread 08-01-2011, 18:34
Mike Ounsworth's Avatar
Mike Ounsworth Mike Ounsworth is offline
Roboticist
FRC #3710 (Cyber Falcons)
Mike Ounsworth is a jewel in the roughMike Ounsworth is a jewel in the roughMike Ounsworth is a jewel in the rough
I'm fairly confident that any free-flying mini-bots will be deemed a safety hazard.
I am doing graduate work on autonomous aerial and underwater vehicles with McGill University's Mobile Robotics Lab.
I have been Lead Programming Mentor with Teams 296 and 3710, as well as Head Mentor for 2 years at 3710.
Unread 08-01-2011, 18:37
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
i would agree with this ....flying projectiles are hard to control and could harm a robot or person also the defenition of deployment says that you must place the minibot on the tower and if you dont deploy the minibot it would not count
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 08-01-2011, 18:47
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
What if the minibot is wraped around the pole? could you then catapult it? What if the catapult is connected to the Hostbot and rests on the platform?
Unread 08-01-2011, 18:54
alectronic alectronic is offline
no team (Volunteer)
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
I thought about this too. Although this type of thing is nearly always (from other similar situations) covered in the first rules update. So, it may just be best to hang on for that.
Although my guess is that is will be disallowed.
Unread 08-01-2011, 21:15
SashaKuznetsov's Avatar
SashaKuznetsov SashaKuznetsov is offline
FIRST Team 1279 Member
AKA: Alex Smith
FRC #1279 (Cold Fusion)
SashaKuznetsov is an unknown quantity at this point
Firstly:
Your catapult would have to have a lever that would stop with the top of the minibot below the deployment line, because:
<G22> HOSTBOTS may not contact their ALLIANCE’S MINIBOT once it has climbed above the DEPLOYMENT LINE. Violation: TOWER is disabled
So yeah, don't try it.
Also:
When reading these rules, please use technical commonsense (engineering thinking) rather than "lawyering" the interpretation and splitting hairs over the precise wording in an attempt to find loopholes. Try to understand the reasoning behind a rule.
Don't mix up innovation with wanting to beat the system. As long as you understand that, keep ideaing away!
Cold Fusion-Come chill with us
Unread 08-01-2011, 22:00
RandAlThor RandAlThor is offline
FRC #0115
RandAlThor is an unknown quantity at this point
Lightbulb Re: Catapulting minibot
Coupled with the loophole that allows a robot to have multiple minirobots, could you deploy a minirobot that has the sole purpose of shooting another minibot up the pole? (the projectile minibot being a sort of carabiner-like object that latches onto the pole)
Unread 08-01-2011, 22:07
kgzak's Avatar
AKA: Kris
I am not trying to beat the system or anything I just don't see what in the rules prevents you from launching the minibot from the base. You wouldn't have to make your minbot break the plane while touching it, you have 18 inches. I have asked in the Q&A and that will give the official answer. I personally don't think it will be legal, but who knows.
Unread 08-01-2011, 22:16
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
I would imagine that they are going to eventually clarify deployment further and say that it ends when the minibot eventually grabs the tower or hits the top. If that were that case, it would be considered deploying above the deployment line to launch it at all. At least that is the impression I've been getting while I read the rules.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 08-01-2011, 22:24
chris janney chris janney is offline
FRC #3266
chris janney is an unknown quantity at this point
im pretty sure the reason we cant catapult the minibot is becuase of people like me. my first thought was to strap a small rocket engine on the thing and forget about it. right now im shooting (no pun intended) for building a scaled down air cannon and turning it upside down so the air jetisons the bot into space.
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
I had a similar idea, but to deploy the minibot legally and then launch it to the top with a spring/pneumatic system of some kind. Nothing in the rules against that XD This is gonna be fun....
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
