Go to Post From what I've been told, it's BASIC. Just BASIC. Basic BASIC. Basically BASIC. To be basic, it's BASIC. - Aignam [more]
Unread 08-01-2011, 23:46
tetravaal tetravaal is offline
FRC #2461
tetravaal is an unknown quantity at this point
Easy Q - Where can I get the example code for 2011
Our team had a dedicated programmer that unfortunately doesnt have the time to donate to the cause anymore! As such im going to try to take over those duties with NO prior knowlege, but last I knew each year some example code (default code?) is provided.
Searched all over the FRC site and I havent been able to locate it.. Can anyone point me in the right direction?
Joe
Unread 08-01-2011, 23:54
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Re: Easy Q - Where can I get the example code for 2011
Well first you have to apply the updates for your respective language.
http://usfirst.org/roboticsprograms/....aspx?id=18758
Once you update your software, the new example code (floor line tracker and some more goodies) are then present.
Have anymore questions? Feel free to ask!
Unread 09-01-2011, 00:21
FRC #2461
Thanks dShad! Now to the easy part of programming!
Unread 09-01-2011, 03:28
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Quick tip: If you read over the manual, it tells you how to do basic stuff like how to create a new project, how to upload it, how to run it...etc.
Also, we learned how to program by looking at sample code, but eventually scrapped the sample code and rewrote it in the end. Something to consider.
Unread 09-01-2011, 10:54
Like Patrick said, the sample code is actually a lot. It there are also tons of examples on CD and on the software itself.
