Go to Post "The reason we struggle with insecurity is because we compare our behind-the-scenes with everyone else's highlight reel." - davidthefat [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 08-01-2011, 20:37
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: 2011 Logomotion Mini Bots
Originally Posted by byteit101 View Post
not necessarily, you could have a three way switch that connects the battery directly to the motor forward, backwards, and off, and the main robot could turn it on, deploy it, it would hit the top, flipping the switch, sending it in reverse. No wasted battery, no code
Exactly. The minibot rule section states you can use some common household light switches. Seems trivial to set up your deployment system to flip it on as it goes up.
Even if you left it always on, I don't think ~4 mins will kill the battery. Then again, I don't know the life of these batteries.
Unread 09-01-2011, 00:22
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
The NXT may be programmed in LabVIEW. There are libraries available, and it is easier to program then the cRIO. FRCmastery.com is the sister to FTCmastery.com. There are videos and help on both sites.
Mike B
Unread 09-01-2011, 08:46
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
I was thinking about this same issue. Wouldn't sapping power from the main robot to power the minibot eliminate the need to place batteries on the minibot? The rule people on our team are still looking this up, but still would be a good idea if legal (minimum code if at all, and super light).
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Unread 09-01-2011, 15:32
PSHRobotics PSHRobotics is offline
FRC #1182
PSHRobotics is an unknown quantity at this point
How would you manage to have the minibot continue up the pole once it is disconnected from the main robot?
Also, LabView is pretty popular for FTC. The FTC section on CD has several teams that use it, including mine.
Now what I'm worried about is access to the libraries for FTC and FRC at the same time. My team has tried to install (last season, not this season) FRC's LabView directly over the version for FTC. The install always failed over three labtops. We had to completely remove everything related to FTC's LabView before installing FRC's LabView. Hopefully this will not be too big of a problem because an "FTC Toolkit" is released to use with LabView which should contain all the libraries for FTC. You can get the Toolkit off of USFirst.org's FTC Programming section in the "LabView Resources" link." Tomorrow, I will try installing the ToolKit over this FRC's LabView and then try to compile our most recent FTC code. I will post any problems or successes here.
Unread 09-01-2011, 15:43
AKA: Matt B
FRC #1771 (1771)
How is the minibot going to retain power? Super-caps?
Unread 09-01-2011, 17:20
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Interesting you should have this problem.
I know this was an issue for FRC 2009 and FTC 2008/09, but since then FTC and FRC have used different versions of LabVIEW.
I just yesterday installed FRC LabVIEW on laptops with the FTC LabVIEW.
Could you PM me with more details of your issue?
-- Marshal Horn
Unread 09-01-2011, 17:35
To answer all those who questioned how i would keep power to the robot, our team would use a really long wire and tether it to the robot. I thought I could make it like those old rc car power systems (except with no manual control). Just a thought.
Unread 09-01-2011, 18:04
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Minibots must not exceed a 12" x 12" x 12" volume.
Rule <G41>
-- Marshal Horn
Unread 09-01-2011, 18:26
Rule <G41>
That is what i was afraid of. It is a grey area in my book. Does the wire count as a part of the main robot or the minibot?
Unread 09-01-2011, 18:28
AKA: Matt B
FRC #1771 (1771)
That wire would count as both.
The MINIBOT has to come OFF OF the HOSTBOT.
Unread 09-01-2011, 18:30
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Oh, then you're looking for a different rule:
<G19> after deployment, minibots must remain completely autonomous
<G22> Hostbots may not contact their alliance's minibot once it has climbed above the deployment line.
In summary, your minibot can not be powered by the robot once it climbs above 18 inches; its sources of mechanical power is effectively limited to stretched surgical tubing, the Tetrix battery, or inertia.
-- Marshal Horn
Unread 09-01-2011, 18:54
Yeah, those rules basically kill the tethering idea all together. This forces the minibots to have battery packs/other bulky energy devices which weigh them down. Thanks for the input guys!
Unread 09-01-2011, 21:21
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
<G19> After DEPLOYMENT, MINIBOTS must remain completely autonomous.
Other rules also apply such as the Minibot cannot be wired to the "Hostbot"
<G22> HOSTBOTS may not contact their ALLIANCE'S MINIBOT once it has climbed above the DEPLOYMENT LINE.
So yes, completely autonomous is the only choice, without any driver interaction as all communication between the minibot via the controller via the NXT controller is illegal due to bluetooth being disabled (as I understand it)
<R92> E. No more than one NXT controller with the Bluetooth functionality disabled
EDIT: My browser open from yesterday and I didn't notice, sorry for bumping this AND reposting information already posted :/
Unread 10-01-2011, 02:14
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
As long as they fit with in the 12" cube and the 15 pound weight limit is there any reason a robot could not carry two minibots?
Unread 10-01-2011, 09:03
Guppy's Avatar
Guppy Guppy is offline
FRC #3344 (Fayette R0B0C0PZ)
Team Role: Tactician
Guppy is an unknown quantity at this point
I don't know if two minibots on the same robot would be beneficial. If you build a system to hook it up to your alliance member's bot, then not only could both poles be climbed faster, but you get a "coopertition" point for sharing your second minibot. And my team uses FTC to train our rookies to get ready for FRC, so to shed light on the battery life, our battery usually is changed probably once during an all day competition. The NXT brick usually lasts all day. If you charge the Tetrix battery between matches, it will be fine. The NXT brick just takes double A's, so even if it runs out of battery (which is unlikely), it should be easy to change batteries. If you don't mind, I think I may digress for a second. Has anyone attempted to reverse-engineer the minibots from the video? I think I may have been able to build it on CAD, but I don't know how well it would work.
