#16
Re: Catapulting minibot
use the pvc pipe to make a barrel and a holding tank. the stuff can take a lot of pressure, so as long as you charged it on the host bot it will be fine. besides my team doesnt feel like putting a hole in the roof of the shop we are using, so it probably wont happen.
#18
PVC air tanks are prohibited as they are not pneumatic components.
All of you are going about wrong. Store the energy in the minibot... |
#19
i was considering something similar, but was worried about the possibility of not having enough force to reach the 2-4 N needed to activate the sensor- so.. maybe a combination of a self powered bot and a boost from host?
#20
<G26> If at any time a ROBOT'S operation or design is deemed unsafe, the ROBOT will be disabled for the remainder of the MATCH. If the safety violation is due to the ROBOT design, the Head Referee has the option to not allow the ROBOT back onto the FIELD until the design has been corrected. Violation: PENALTY and Disablement
#21
What I was wondering was what constituted a robot, and what the minimum definition of a mini-bot was, because if it is just any extension to the robot that can latch onto the pole and/or detach from the robot, then I could just build a little box that houses a lot of pre-tensioned surgical tubing, clipped to the pole with a carabiner or something similar, positioned so that when it detached to released all of the Potential Energy at once, launching the cube upwards at a very high velocity, I could even add a foam layer so that it wouldn't hurt the field. I honestly cant think of a faster way to get from point A to B. and input on the legality of it or the minimum requirements of a mini-bot (i.e. a brain, batteries, motors, ect.) would be greatly appreciated.
#22
An "autonomous vehicle", not a projectile/wind-up toy. Build a TETRIX robot, or don't bother... My take Also I and others said in other threads, the autonomous requirement kicks in as soon as the minibot is deployed (positioned) on the tower/pole. And, its a climbing race. The Host cannot impart momentum without violating autonomy or the definition of climbing. ![]() Last edited by Randy Picolet : 09-01-2011 at 01:32. |
#23
And what if our "deployment" is not finished until AFTER we release our surgical tubing/spring? |
#24
Positioning means locating at a point, not applying force. Once you haver positioned the minibot, it must be autonomous (fully self-controlled) Climbing implies continuous non-sliding contact, as opposed to jumping. sliding. slinging, or flying using a pole as a trajectory constraint/guide. You probably can use elastic energy stored on the minibot (assuming it passes safety inspection) but I think you will still not be able to just slide along the pole; you need traction of some sort to qualify as climbing IMHO. |
#26
![]() Not sure I said "intelligently" anywhere. And I believe it would still be a legal minibot without a brick/brain. I just don't think you will get very far without one if you think about the whole problem (e.g. intentionally free-falling back down after you hit the target is probably gonna get you a flag). And if the mini touches the host after it climbs above the deployment line, that would violate <G22>, so you'd have to pull the host out of the way, which means the minibot would slam into the base. Autonomous means "self-control", not "no control" ![]() Last edited by Randy Picolet : 09-01-2011 at 02:10. Reason: typos |
#27
<G19> After DEPLOYMENT, MINIBOTS must remain completely autonomous. the minibots only have to be autonomous (in my opinion means not being acted upon by other objects such as the hostbot) AFTER deployment. the definition for deployment only definitively states when it starts. therefore with some more nitpicking of the rules (this is how loop bot, i believe it was team 469, dominated most of last years competition) i came across this rule <G22> HOSTBOTS may not contact their ALLIANCE’S MINIBOT once it has climbed above the DEPLOYMENT LINE. these two rules and the shabby definition of deployment lead me to believe that until it gets stated otherwise, one can "shoot" the minibot off of the host bot in endgame and also i don't see how climbing implies continuous non-sliding contact. tl;dr i read you can "shoot" minibots up the pole in endgame |
#28
No part of the rules says this at all.
#29
and all you need to do in order to pad your landing would be to line the bottom of your robot with surgical tubing. and ya there is no rule against that^^^
#30
Even if you need to have non-sliding contact, you can just put a wheel on the robot so that it might touch the pole on the way up.
But has anyone done the projectile motion calculations to figure out how hard we have to propel an object upwards in order for it to exert 2-4 newtons at the top? |
