Go to Post If FIRST isn't your life, then you're doing something wrong! - BandChick [more]
Unread 09-01-2011, 02:06
Randy Picolet's Avatar
Randy Picolet Randy Picolet is offline
Caffeine Addic..um..Afficionado
FRC #2159 (RoboPirates)
Randy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud of
Re: Catapulting minibot
Originally Posted by ICanCountTo19 View Post
I completely disagree. Autonomous simply means acting independently. It never says intelligently. Who's to say we even need to use the brick. I saw a team, while judging at the state FLL competition this year, who had their robot hit a lever for a large box. The robot never left the base for this program. Within this box was a spring loaded mechanical arm that placed the bone bridge (I think that's what it was called) exactly in the right location every time. Why build a complicated minibot with an FTC kit instead of just a box that fires itself off.
I love a good techie debate
Not sure I said "intelligently" anywhere. And I believe it would still be a legal minibot without a brick/brain. I just don't think you will get very far without one if you think about the whole problem (e.g. intentionally free-falling back down after you hit the target is probably gonna get you a flag). And if the mini touches the host after it climbs above the deployment line, that would violate <G22>, so you'd have to pull the host out of the way, which means the minibot would slam into the base. Autonomous means "self-control", not "no control"
