Go to Post Everything is possible. Some things are just harder to do than others. - vigkvagkv2 [more]
Unread 08-01-2011, 22:40
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Catapulting minibot
Originally Posted by chris janney View Post
im pretty sure the reason we cant catapult the minibot is becuase of people like me. my first thought was to strap a small rocket engine on the thing and forget about it. right now im shooting (no pun intended) for building a scaled down air cannon and turning it upside down so the air jetisons the bot into space.
Good luck finding a small air cannon in the FTC kit of parts
Unread 08-01-2011, 22:44
chris janney chris janney is offline
FRC #3266
chris janney is an unknown quantity at this point
use the pvc pipe to make a barrel and a holding tank. the stuff can take a lot of pressure, so as long as you charged it on the host bot it will be fine. besides my team doesnt feel like putting a hole in the roof of the shop we are using, so it probably wont happen.
Unread 08-01-2011, 22:47
Chris is me's Avatar
AKA: Pinecone
PVC air tanks are prohibited as they are not pneumatic components.
All of you are going about wrong. Store the energy in the minibot...
Unread 08-01-2011, 22:57
ecogirl5595 ecogirl5595 is offline
FRC #3125 (Pirates of the Pythagorean)
ecogirl5595 is an unknown quantity at this point
i was considering something similar, but was worried about the possibility of not having enough force to reach the 2-4 N needed to activate the sensor- so.. maybe a combination of a self powered bot and a boost from host?
Unread 08-01-2011, 22:58
kerrigan93's Avatar
kerrigan93 kerrigan93 is offline
Head of Design Crew
FRC #1165 (Team Paradise)
kerrigan93 is an unknown quantity at this point
Originally Posted by Mike Ounsworth View Post
I'm fairly confident that any free-flying mini-bots will be deemed a safety hazard.
<G26> If at any time a ROBOT'S operation or design is deemed unsafe, the ROBOT will be disabled for the remainder of the MATCH. If the safety violation is due to the ROBOT design, the Head Referee has the option to not allow the ROBOT back onto the FIELD until the design has been corrected. Violation: PENALTY and Disablement
Unread 09-01-2011, 00:47
Timebomb Timebomb is offline
AKA: Chris Howard
FRC #4682 (Bravebots)
Timebomb is an unknown quantity at this point
What I was wondering was what constituted a robot, and what the minimum definition of a mini-bot was, because if it is just any extension to the robot that can latch onto the pole and/or detach from the robot, then I could just build a little box that houses a lot of pre-tensioned surgical tubing, clipped to the pole with a carabiner or something similar, positioned so that when it detached to released all of the Potential Energy at once, launching the cube upwards at a very high velocity, I could even add a foam layer so that it wouldn't hurt the field. I honestly cant think of a faster way to get from point A to B. and input on the legality of it or the minimum requirements of a mini-bot (i.e. a brain, batteries, motors, ect.) would be greatly appreciated.
Unread 09-01-2011, 01:29
Randy Picolet's Avatar
Randy Picolet Randy Picolet is offline
Caffeine Addic..um..Afficionado
FRC #2159 (RoboPirates)
Randy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud of
"MINIBOT – an autonomous vehicle designed and built to perform specific tasks when competing in the 2011 competition LogoMotion. The MINIBOT must obviously follow a design approach intended to play the 2011 FRC END GAME and must be compliant with all MINIBOT rules defined in Section 3.4.14. [sic s/b 4.3.14]"
An "autonomous vehicle", not a projectile/wind-up toy. Build a TETRIX robot, or don't bother... My take
Also I and others said in other threads, the autonomous requirement kicks in as soon as the minibot is deployed (positioned) on the tower/pole. And, its a climbing race. The Host cannot impart momentum without violating autonomy or the definition of climbing.
Unread 09-01-2011, 01:35
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
I still think a small block designed to sling upwards would fit the definition of a MINIBOT. No where in the manual does it state that the MINIBOT must contain electronics, or motors.
And what if our "deployment" is not finished until AFTER we release our surgical tubing/spring?
Unread 09-01-2011, 01:46
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
I completely disagree. Autonomous simply means acting independently. It never says intelligently. Who's to say we even need to use the brick. I saw a team, while judging at the state FLL competition this year, who had their robot hit a lever for a large box. The robot never left the base for this program. Within this box was a spring loaded mechanical arm that placed the bone bridge (I think that's what it was called) exactly in the right location every time. Why build a complicated minibot with an FTC kit instead of just a box that fires itself off.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 09-01-2011, 01:53
"DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference during the END GAME. (Related form, DEPLOY, verb)"
Positioning means locating at a point, not applying force. Once you haver positioned the minibot, it must be autonomous (fully self-controlled) Climbing implies continuous non-sliding contact, as opposed to jumping. sliding. slinging, or flying using a pole as a trajectory constraint/guide.
You probably can use elastic energy stored on the minibot (assuming it passes safety inspection) but I think you will still not be able to just slide along the pole; you need traction of some sort to qualify as climbing IMHO.
Unread 09-01-2011, 02:06
I love a good techie debate
Not sure I said "intelligently" anywhere. And I believe it would still be a legal minibot without a brick/brain. I just don't think you will get very far without one if you think about the whole problem (e.g. intentionally free-falling back down after you hit the target is probably gonna get you a flag). And if the mini touches the host after it climbs above the deployment line, that would violate <G22>, so you'd have to pull the host out of the way, which means the minibot would slam into the base. Autonomous means "self-control", not "no control"
Unread 09-01-2011, 02:18
kornjones kornjones is offline
AKA: samuel
FRC #1522 (DOTM)
kornjones is an unknown quantity at this point
the way i read this was that according to this rule:
<G19> After DEPLOYMENT, MINIBOTS must remain completely autonomous.
the minibots only have to be autonomous (in my opinion means not being acted upon by other objects such as the hostbot) AFTER deployment. the definition for deployment only definitively states when it starts.
therefore with some more nitpicking of the rules (this is how loop bot, i believe it was team 469, dominated most of last years competition) i came across this rule
<G22> HOSTBOTS may not contact their ALLIANCE’S MINIBOT once it has climbed above the DEPLOYMENT LINE.
these two rules and the shabby definition of deployment lead me to believe that until it gets stated otherwise, one can "shoot" the minibot off of the host bot in endgame
and also i don't see how climbing implies continuous non-sliding contact.
tl;dr i read you can "shoot" minibots up the pole in endgame
Unread 09-01-2011, 02:19
AKA: Pinecone
No part of the rules says this at all.
Unread 09-01-2011, 02:29
AKA: samuel
FRC #1522 (DOTM)
and all you need to do in order to pad your landing would be to line the bottom of your robot with surgical tubing. and ya there is no rule against that^^^
Unread 09-01-2011, 02:51
RandAlThor RandAlThor is offline
FRC #0115
RandAlThor is an unknown quantity at this point
Even if you need to have non-sliding contact, you can just put a wheel on the robot so that it might touch the pole on the way up.
But has anyone done the projectile motion calculations to figure out how hard we have to propel an object upwards in order for it to exert 2-4 newtons at the top?
