Go to Post Wow, my dad's sadistic nature is rubbing off on me. - Lil' Lavery [more]
Unread 08-01-2011, 23:35
ATannahill ATannahill is offline
AKA: Alex Tannahill
G02 clarification
I think this is a subject for the Q&A but I want to pass it by CD while the Q&A is closed.
G02 states
Originally Posted by Section 3 - The Game
<G02> The AUTONOMOUS PERIOD ends when the ARENA timer displays zero seconds. The MATCH ends if all TOWERS are TRIGGERED or when the ARENA timer displays zero seconds, whichever comes first.
Will the match end when all towers are triggered or disabled, or just triggered? i.e. If I accidentally let the minibot go early onto the pole, will that prevent the match from ending early?
- Arizona North
Unread 08-01-2011, 23:43
mcrawford mcrawford is offline
Zac Efron-461
FRC #0461 (West Side Boiler Invasion)
mcrawford is an unknown quantity at this point
Re: G02 clarification
It says nothing about disabling a tower so No. They all have to be TRIGGERED or the time runs out. Besides the towers could all be disabled as early as during autonomous is four teams were really stupid and wanted to get penalties.
Unread 08-01-2011, 23:44
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
I would assume disabled would also count, logically, even though its not specified exactly. Of course, the GDC won't realize this if they don't hear about it, so you'd better ask them.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 08-01-2011, 23:46
AKA: Alex Tannahill
Under G17, G20 and G22 (the rules that disable the tower) there are no penalties.
- Arizona North
Unread 09-01-2011, 03:10
1631JD 1631JD is offline
Psychotron
AKA: Jordan
FRC #1631 (Rockin' Robots)
Team Role: Tactician
1631JD is an unknown quantity at this point
It is a matter of seconds difference; however, I think that if a tower is disabled then all active towers triggered will stop the game.
Unread 09-01-2011, 06:27
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
I have found in past years it really does come down to the wording. In this case ,though it is literally a matter of seconds, the match will end only if they are TRIGGERED or the timer runs to 0. The fact that it doesn't state the disabled state means it is not likely to be considered...
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 12-01-2011, 12:15
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
So to make sure I've got my head wrapped around this rule:
Bluabots 1 & 2 and Redabot 1 has deployed their minibots, and have triggered.
Redabot 3 has a game piece and it will take them 4 seconds to score.
Redabot 2 is deploying its minibot, it takes 3.5 seconds to reach the trigger.
There are 5 seconds left in the match.
Redabot 3 will not score, correct?
Hi!
Unread 12-01-2011, 12:17
AKA: Alex Tannahill
That is exactly how I read it.
- Arizona North
Unread 12-01-2011, 12:32
If Redabot 3's last half second of scoring action requires powered full control of the robot, I do believe you are correct.
If the robot is in the process of doing something when the match ends, and if that something can continue on its own momentum with the game piece ending up on the peg with the robot no longer touching it a second or so later, the crowd will cheer and the piece will be scored.
Unread 12-01-2011, 12:59
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
In 2007 the robot could not be touching the tube, so if the momentum carries it to the peg and the "gripper" has no contact then it could score.
This Game rule is a significant change from previous years. I would expect some more clarification on this one. Especially given that only 4 bots can deploy minibots, the other 2 should be trying to score tubes. A few seconds can win or lose a match.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
