Go to Post Instead of lowering a team's expectations, let's raise the amount of competitive resources available to them. ;) - artdutra04 [more]
Unread 09-01-2011, 09:25
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Pneumatic Storage Tanks in 2011
I cant seem to find anywhere in the manual where it limits then number or size of pneumatic storage tanks,
Can anyone confirm this?
Thanks
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 09-01-2011, 11:15
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: Pneumatic Storage Tanks in 2011
The rules this year are very lax for pneumatics. As of now, cylinders and storage tanks are not limited.
FIRST may release a pneumatics supplement sometime soon like they have done for the past couple years.
Unread 09-01-2011, 11:25
JHammond JHammond is offline
FRC #0811
JHammond is just really niceJHammond is just really niceJHammond is just really niceJHammond is just really nice
It seems like the rules are a big vague WRT to tanks.
<R65> To satisfy multiple constraints associated with safety, consistency, robot inspection, and constructive innovation, no pneumatic parts other than those explicitly permitted by the Pneumatic System Rules may be used on the ROBOT.
<R66> In addition to the items included in the KOP, pneumatic system items specifically permitted on 2011 FRC ROBOTS include the following items...
The elaborated list does not say anything about tanks, but neither does rule <R67> explicitly prohibit additional tanks.
A strict reading of these rules would lead me to conclude we can only use the tank (a bigger one this year) provided in the KOP. A loose reading of these rules would indicate we can use as many tanks as we want, assuming they support a working pressure of 125PSI and a burst pressure of 250 PSI.
Also, is <R74> new this year? I could swear I saw this sort of design implemented on a few robots last year.
Thanks!
Jeffrey
Unread 09-01-2011, 11:28
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Yes, there was no rule like this in the past couple manuals.
Unread 09-01-2011, 11:35
Bochek's Avatar
AKA: Adam Bochek
After re-reading that part, i seem to agree that we are only allowed the one larger sized storage tank.
Unread 09-01-2011, 11:38
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I agree with the conclusion that, as written, the rules appear to allow only the single tank from the KOP to be used or an additional tank if acquired through FIRST Choice.
Given the availability through FIRST Choice, my belief is that the rules will be amended as necessary to allow additional air storage tanks. The limit of a single solenoid valve per movement (<R74>) limits the power level of any individual cylinder motion so limiting the max storage volume was likely seen as unnecessary.
*Note that most of the above is opinion, interpretation or speculation and should not be taken as robot legal advice*
Unread 09-01-2011, 11:51
pfosx's Avatar
pfosx pfosx is offline
AKA: Paul Fossenier
FRC #3161 (Tronic Titans)
pfosx is an unknown quantity at this point
if i'm not mistaken, the storage tank that is available through FIRST Choice is the same as from the 2010 KoP.
The FIRST Choice tank is smaller than the 2011 KoP tank... so, naturally a team would not use the FIRST Choice tank instead of the 2011 KoP tank.
Which leads me into thinking multiple tanks are allowed, how many... i guess we'll have to wait on a ruling.
Dean's List Finalist Award - WAT 2011
Unread 09-01-2011, 11:57
Bochek's Avatar
AKA: Adam Bochek
Are the first Q+A forums open yet? if so can someone link me to them, and i will post this question to them.
Unread 09-01-2011, 12:03
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Nope, I don't see them up yet. If past years are any indicator they will open up on Wednesday.
Unread 09-01-2011, 12:17
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Unfortunately, this seems to be correct—the rules make no mention of cylinders or tanks (or synonyms) as being among the set of non-kit allowable pneumatics parts.
I have to assume this is an oversight.
Unread 09-01-2011, 21:35
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
If we are only allowed the one tank we will be severely handicapped this year almost to the point of pneumatics being useless.
If we are unlimited in storage then wahoooo!!
Unread 09-01-2011, 22:18
hg273's Avatar
hg273 hg273 is offline
AKA: Henry Gordon
FRC #1540 (Flaming Chickens)
hg273 will become famous soon enough
The blue box under <R69> reads "The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in the storage tanks prior to bringing the ROBOT onto the FIELD. (emphasis mine). Additionally, <R70> says Only the compressor,relief valve,pressure switch,pressure vent plug valve,pressure gauge, storage tanks, tubing, and connecting fittings may be in the high-pressure pneumatic circuit upstream from the regulator. (emphasis mine).
As I read it, we're allowed multiple tanks. I'm guessing that FIRST will release a correction, defining how many tanks may be used, but unless that's cleared up, there's no restriction.
I hope this helps!
