Go to Post I don't really care that the best on Curie may or may not be better than Newton, since we're going to spend the rest of the offseason discussing it no matter how the decision fell. - Jessica Boucher [more]
  #31   Spotlight this post!
Unread 09-01-2011, 02:58
Randy Picolet's Avatar
Randy Picolet Randy Picolet is offline
Caffeine Addic..um..Afficionado
FRC #2159 (RoboPirates)
Randy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud of
Re: Catapulting minibot
Originally Posted by Chris is me View Post
No part of the rules says this at all.
True, no rule. I'm just thinking if the mini has enough momentum on the way up to overcome the pole friction and target switch force, you probably have a good bit of mass and so a good bit (even tho probably somewhat less) on the way down. Which might be considered "damaging" to the base. especially if they let everybody do it all the time. Maybe like kornjones said, some well placed padding might save the day...
But its all moot if climbing requires traction, which I'm betting on. The GDC wants a climbing race, not a shoot-em-up-in-the-air, so I think they will either interpret or clarify the existing rules in that direction.
But I could be wrong. That would be oh, 6 or 7 times today... that I know of
  #32   Spotlight this post!
Unread 09-01-2011, 03:09
Oblarg Oblarg is offline
AKA: Eli Barnett
During our discussions today, 449 reached the somewhat tentative conclusion that as the rules are currently written there is nothing explicitly forbidding a minibot that is launched up the pole as a projectile as long as it clamps to the pole in some way and your robot is no longer touching it when it passes the deployment line (which limits the possible displacement of whatever spring mechanism you use to shoot it), however it is more likely than not the rules will be clarified/revised fairly soon to make this illegal, as it completely bypasses what seems to be the intent of the minibot in the first place (i.e. seeking the help of local FTC teams, unifying the various branches of first, etc).
"The breakfast of champions!"
  #33   Spotlight this post!
Unread 09-01-2011, 03:12
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
What if to solve the problem of uncontrolled free-fall the minibot had wheels with a ratchet mechanism. The wheels when going up can spin freely, but when going down the wheels are stuck and provide enough friction for a safe fall
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
  #34   Spotlight this post!
Chris is me's Avatar
AKA: Pinecone
Please, PLEASE don't make design decisions on what you assume the rules meant to be. The Manual is the Manual. Follow the rules, but don't assume FIRST had one robot design in mind.
  #35   Spotlight this post!
Unread 09-01-2011, 03:23
AKA: Eli Barnett
It's not a design decision so much as a development strategy - if it's reasonably likely that a certain approach to a game task despite its seeming innate superiority and comparative simplicity to the alternatives will be deemed illegal, then it's good strategy to plan on designing an alternative so that you're not stranded without a mechanism if the rules are changed (or in this case clarified, as arguments can and have already been made that the wording of "positioning" already rules out launchers).
  #36   Spotlight this post!
Unread 09-01-2011, 07:29
GaryVoshol's Avatar
Cogito ergo arbitro
There are an awful lot of words being used here which have no definition in the rules, only in the poster's minds. We need to use GDC definitions; where something is not defined it has to be asked in Q&A.
(since 2004)
  #37   Spotlight this post!
Unread 09-01-2011, 08:52
menns menns is offline
AKA: Michel Enns
FRC #1310 (Runnymede Robotics)
menns has a spectacular aura aboutmenns has a spectacular aura about
As a physics teacher the solution seems obvious. Have the HOSTBOT wrap many coils of wire around the steel pole. Clip the MINIBOT, which is basically just an aluminum ring, around the pole and then just run a large AC current through the coils of wire. The MINIBOT shoots up the pole by electromagnetic induction.
  #38   Spotlight this post!
Unread 09-01-2011, 09:35
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
AC Current inside a DC-controlled robot. Is there anything in the Rules against a DC to AC Inverter?
I like the concept. This post gave me a good chuckle:}
Team MARS = 1.523 AU from the SUN!
Jim E.
  #39   Spotlight this post!
Unread 09-01-2011, 09:54
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Or since you are allowed polycarb and aluminum plate you can make pretty big capacitor bank to allow the single pulse to push the "Minibot" up the pole. Railgun anyone?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
  #40   Spotlight this post!
Unread 09-01-2011, 10:01
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
This is a cool idea.
However, it might run afoul of <G19>, because the ring would not jump autonomously after deployment. See the Manual, Section 1.6 LogoMotion Glossary: DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference during the END GAME.
I'd like to try it in the shop anyway, just for fun.
Richard Wallace
since 2003
  #41   Spotlight this post!
Unread 09-01-2011, 10:12
AKA: Michel Enns
Oh, I forgot to mention - the MINIBOT would ideally be dipped in liquid nitrogen just before DEPLOYMENT.
  #42   Spotlight this post!
Unread 09-01-2011, 11:02
TheBigCheese TheBigCheese is offline
FRC #0619
TheBigCheese is an unknown quantity at this point
But how exactly would you wrap the coils around the pole?
  #43   Spotlight this post!
Unread 09-01-2011, 11:53
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
FIRST will often often ask you to use accepted definitions, sometimes explicitly in the Q&A. Remember the "active mechanism" fiasco last year? If you apply a more generally accepted definition of autonomous (more than just the context of our "autonomous mode") and then:
  • Consider <G19> After DEPLOYMENT, MINIBOTS must remain completely autonomous.
  • Consider the definition: DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference during the END GAME.
In a broader sense of the word, something that is pushed is not autonomous. Therefore, if it is pushed after it crosses the platform, it is not acting autonomously during DEPLOYMENT.
I imagine someone will get the GDC to clarify after enough prodding, just like they eventually did for "active mechanism" last year.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
  #44   Spotlight this post!
Unread 09-01-2011, 12:41
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Are you serious?
Attending: MN Duluth Regional
  #45   Spotlight this post!
Unread 09-01-2011, 12:48
Power User
AKA: Carl Agnew
Originally Posted by theprgramerdude View Post
Are you serious?
Not even slightly, just having fun. Check out <R92>
