Go to Post On a side note... "Think outside the robot." - I kinda like that. I'll have to use that in a meeting someday.... - Not2B [more]
Unread 09-01-2011, 11:33
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Killbill.exe found in FIRST USB
Before installing the update in our classmate we ran a scan over the USB drive with Microsoft Security Essentials and it actually reported a virus.
Details below
Does anyone have a similar issue?
Unread 09-01-2011, 11:37
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Re: Killbill.exe found in FIRST USB
what year classmate do you have? was this the image for the 2010 classmate or for the 2011 classmate?
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 09-01-2011, 11:39
AKA: Yamil Asusta
2010
Unread 09-01-2011, 11:41
Bochek's Avatar
AKA: Adam Bochek
We are currently Scanning ours, will get back to you in a bit.
Edit: Nothing found using AVG Free.
Unread 09-01-2011, 12:12
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Usually if something edits another program, virus scanners see it as a trojan even if it isn't. An image could easily be considered a trojan because it edits the code of other programs. That may be what the issue is. Unless you have plugged the flashdrive into something you aren't supposed to, the flashdrive should be completely safe. I have seen plenty of clean files pop up as 'trojans' to virus scanners.
"Don't worry, programming can fix it"
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
That might be the executable file that modifies the registries and whatnot to allow for that driver station to work. They have to remove all the menus and deny running other programs in driver mode.
Because Windows Essentials picked it up and AVG did not, I can adduce that my statement is true. The Essentials are looking for files that will modify the OS in anyway and call it a trojan.
Unread 09-01-2011, 18:13
Erik Huang's Avatar
Erik Huang Erik Huang is offline
Jack of all Trades, Master of None
FRC #0296 (Northern Knights)
Erik Huang is a jewel in the roughErik Huang is a jewel in the roughErik Huang is a jewel in the rough
well then why would it be called killbill.exe? i don't think it's a FIRST easter egg...
Here ye, here ye! Here cometh the robot!
Unread 09-01-2011, 18:18
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Some digging on Google suggests that this is a false positive and that the file is related to Webcam drivers. I'm not sure why the file is named the way it is, but it does not appear to be an actual trojan or virus.
Unread 14-01-2011, 23:04
NetPlanet NetPlanet is offline
AKA: Michael Bilinsky
FRC #0296 (The Northern Knights)
NetPlanet is an unknown quantity at this point
I just finished installing AVG free (not the trial version that comes with the update after re-imaging the 2010 classmate) and it detected and quarantined this exact file somewhere on the classmate itself after a scan.
For a false positive, why the menacing name?
Unread 15-01-2011, 09:31
Team1559is1337 Team1559is1337 is offline
None #1559
Team1559is1337 is an unknown quantity at this point
Question Re: Killbill.exe found in FIRST USB
Hey, so im just wondering why it says 1/4/1980, jw.
Unread 15-01-2011, 16:09
1 Winged Angel 1 Winged Angel is offline
Mentor/Alumni/Guitarist/Programmer
AKA: Nicholas Henry
FRC #0841 (The BioMechs)
1 Winged Angel is an unknown quantity at this point
Send a message via AIM to 1 Winged Angel Send a message via MSN to 1 Winged Angel Send a message via Yahoo to 1 Winged Angel
You should scan with Malwarebytes. Tends to be more effective than AVG Free in scanning files at times.
