Go to Post I think that is important to note that winning teams have won without bending the rules. GP allows you to go ask, investigate and take pictures. Learn from others when you have the chance. - Al Skierkiewicz [more]
  #31   Spotlight this post!
Unread 09-01-2011, 00:58
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Re: Do minibots need to stay at the top of the pole?
Quoting Violation for rule <G20>, not the rule itself. "TOWER is disabled if MINIBOT is DEPLOYED above the DEPLOYMENT LINE."
www.sharkattack744.com
  #32   Spotlight this post!
Unread 09-01-2011, 00:59
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Yes but what if the minibot can jump under it's own power by means of stretched tubing?
Go REX!!!
  #33   Spotlight this post!
Unread 09-01-2011, 07:42
ATannahill ATannahill is offline
AKA: Alex Tannahill
Originally Posted by Randy Picolet View Post
Deployment "ends" when the minibot is "positioned on" the tower, by definition. Autonomous for the minibot starts immediately, you can't do anything after that to help it out. My take....
Your take means nothing. Either cite the manual or an official source.
- Arizona North
  #34   Spotlight this post!
Unread 09-01-2011, 14:08
yujason007 yujason007 is offline
mech monkey
FRC #1072 (Harker Robotics)
yujason007 is an unknown quantity at this point
<R101>If a MINIBOT is rejected by inspectors due to a safety issue or concern related to the team’s method of storing energy, the concerned items must be disabled or removed from the MINIBOT before it can compete in a MATCH. The team bears the burden of proof that such a rejection is not valid. Teams should be prepared to provide justifiable test data or calculations during inspection to support their design.
I'm sure they can easily use that rule to disqualify any robot using "unsafe" methods of energy storage.
  #35   Spotlight this post!
Unread 09-01-2011, 14:46
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
hey everyone im sitting here a day after kick off reading ppls posts and i cant help but notice, you guys are worrying about how much force it takes once the minibot reaches the top of the post. 2 - 4 newtons is only like a half pound to a pound of force for it to register. All your minibot has to to is just touch it and it'll register! If its got enough force to climb the post, its got plenty of torque to register. lol
Nemisis
Team 2389
  #36   Spotlight this post!
Unread 09-01-2011, 14:47
Randy Picolet's Avatar
Randy Picolet Randy Picolet is offline
Caffeine Addic..um..Afficionado
FRC #2159 (RoboPirates)
Randy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud of
I'm sure you simply meant that my opinion doesn't count any more than anyone else's, and I would completely agree. I did cite the manual in a slightly earlier post in this thread (and in a couple of other related threads), and did not wish to paste in yet again. Clearly, the only opinions that count are the rulings of the GDC, but the point here is to share/discuss our opinions until we can get clarification. Otherwise, why bother with the thread at all?
If you disagree with my take on an issue, that's great. I'd like to hear your reasoning if you want to elaborate. Maybe you can change my mind, maybe I can change yours, maybe we can come up with an approach that includes both our viewpoints, or maybe we'll both turn out to be partially right and wrong...
Last edited by Randy Picolet : 09-01-2011 at 14:52. Reason: Better wording to avoid misunderstanding...
  #37   Spotlight this post!
Unread 09-01-2011, 20:59
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Reading also the definition of DEPLOYMENT:
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference during the END GAME. (Related form, DEPLOY, verb)
It seems that it could be possible to launch a minibot outside the vertical projection of the tower base and above the deployment line as long as the hostbot lets go of the minibot before the minibot breaks the projection. If this is true, then I figure it would much easier to launch the minibot at top of the hostbot since the distance to the sensor would be much less.
Does this seem legal? I feel this is not in the spirit in the game but as far as I can tell it seems legal but perhaps technically difficult to achieve.
  #38   Spotlight this post!
Unread 09-01-2011, 21:29
AlexBish_GRR AlexBish_GRR is offline
AKA: Alex Bischoping
FRC #0340 (GRR)
AlexBish_GRR will become famous soon enough
The way i saw things was that you can only use certain items as specified in the rule book and you cant use certain other items but i believe that the rules did state that a minibot needed exactly one battery ie no more no less
  #39   Spotlight this post!
Unread 09-01-2011, 21:42
ttldomination's Avatar
Sunny
I believe the line that you are thinking of states that are you allowed only one battery. This is to ensure that one does not use more than one power source on their minibot, and I do not believe that any team is obligated to have one.
One could've argued that redirecting balls off the overpass wasn't in the "spirit" of the game, but the spirit of the game, and the game are essentially two different things.
- Sunny
1648: 2013-2014
5283: 2015
  #40   Spotlight this post!
Unread 09-01-2011, 22:02
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Jazonk View Post
By this definition, it doesn't seem that it needs to remain there, it just needs to touch the top.
I like this interpretation and agree with it.
Originally Posted by sloteera View Post
I think that if you store some energy (like elastic through rubbers i.e.) on your ROBOT to launch your MINIBOT, it won't be autonomous.
Is storing energy with rubber any different from storing energy chemically (i.e., a battery)?
Originally Posted by princessnatalie View Post
But wouldn't "giving a boost" be illegal?
<snip>
Which to my understanding is as soon as the mini bot or deployment like device is anywhere over the base.
If the second assertion were true - deployment takes place the instant the robot touches the plane of the base - then my Hostbot's pushing it the rest of the way TO the tower pole wouldn't be allowed, because it's not autonomous on the part of the minibot. Right?
OK, so let's theorize that we CAN in fact continue to push Minibot to the pole. As soon as we RELEASE minibot, it must be autonomous.
What if I release it with a huge spring? It's moving up at 10 m/s, hostbot isn't touching it...and when it slows down enough, the motors take over, propelling minibot the rest of the way to the top.
Does that sound illegal?
  #41   Spotlight this post!
Unread 09-01-2011, 23:26
TheMuffinMan53 TheMuffinMan53 is offline
TheMuffinMan53
AKA: Michael
TheMuffinMan53 is an unknown quantity at this point
what would you make the spring out of as there is not a spring in the list of parts you can use for the minibot
Aussie Aussie Aussie Oi Oi Oi
FIRST in Australia
  #42   Spotlight this post!
Unread 09-01-2011, 23:28
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
On the minibots, you could manipulate rubber bands or surgical tubing to store energy. Just an idea.
I don't think that we're sure about the legality of it, but we could also have springs on the hostbots that could make the minibot spring up.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #43   Spotlight this post!
Unread 09-01-2011, 23:34
Aussie Oi!'s Avatar
Aussie Oi! Aussie Oi! is offline
FRC #3132
Aussie Oi! is an unknown quantity at this point
Question Re: Do minibots need to stay at the top of the pole?
could you make the your minibot climb over th other minibot
  #44   Spotlight this post!
Unread 09-01-2011, 23:38
AKA: Kara Bakowski
As in making your robot climb over an opponent's robot to beat them up? No. See <G21>.
Kara Bakowski
WMWBS '10 '11
  #45   Spotlight this post!
Unread 09-01-2011, 23:42
Hallry's Avatar
Hallry Hallry is online now
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Definitely not the opposing alliance's minibot, but as for your own alliance's minibot, such as in the case it stopped working, I don't know...the Q&A opens on Wednesday
