Go to Post 119.9999999 pounds...if only the programmers could make the code a bit lighter! - James1902 [more]
Unread 09-01-2011, 15:00
IdaNeStr3088 IdaNeStr3088 is offline
Crazy Enough To Work&Play BreakAway
AKA: IdaNeStr
FRC #3088 (Kill-O-Bites)
IdaNeStr3088 is an unknown quantity at this point
Is there any restriction for the minibot deployment?
Can we put the minibot at the middle of the pole and then let him going up by its self or we cannot??
because we have been disscusing this idea that maybe we can put the minibot directly on the top of the pole.
I have read the manual and haven't find any restriction. did someone find?
Thanks for a head and sorry if there is a restriction and I have just skipped it.
Unread 09-01-2011, 15:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Is there any restriction for the minibot deployment?
Go back and read the manual again. It's in there.
Unread 09-01-2011, 15:07
musicman musicman is offline
FRC #2531
musicman is on a distinguished road
There is a restriction you can only deploy the minibot below the 18" mark otherwise the tower is deactivated.
Unread 09-01-2011, 15:08
Randy Picolet's Avatar
Randy Picolet Randy Picolet is offline
Caffeine Addic..um..Afficionado
FRC #2159 (RoboPirates)
Randy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud of
Make sure to read the glossary in section 1:
DEPLOYMENT LINE – located on the POST, approximately 18 inches above the top surface of the BASE.
Combined with:
<G20> ROBOTS/HOSTBOTS may not contact their own TOWERS above the DEPLOYMENT LINE.
and
<G22> HOSTBOTS may not contact their ALLIANCE’S MINIBOT once it has climbed above the DEPLOYMENT LINE
means no, you cannot.
Unread 09-01-2011, 15:09
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
DEPLOYMENT LINE.
Violation: TOWER is disabled
This being said, you cannot possibly deploy your mini-bot above the deployment line, unless you want your tower to be disabled.
If you are trying to place your mini-bot halfway up the tower, you are contacting it when you have the mini-bot above the deployment line, which goes against this rule. Your tower will be disabled.
Unread 09-01-2011, 15:10
scottmacdonald's Avatar
scottmacdonald scottmacdonald is offline
AKA: Scott Macdonald
FRC #0610 (Coyotes)
scottmacdonald has a spectacular aura aboutscottmacdonald has a spectacular aura aboutscottmacdonald has a spectacular aura about
See rule <G20> and <G22>
"Don't let him near the machines, he just hurt himself in the computer lab."
Crescent School '11
Queen's University BSc - Physics '15
