| View Poll Results: Mecanum or 6WD | |||
| Mecanum |
90 | 40.36% |
| 6WD |
133 | 59.64% |
| Voters: 223. You may not vote on this poll | |||
Re: Mecanum or 6WD
The rules state that four motors is max just fyi.
Re: Mecanum or 6WD
You can have a max of 4 cims plus the motors included in the kop.
I would go with 6wd over mecanum in a heartbeat. Mecanums as mentioned have no pushing power and you won't be driving as fast around the field either. One problem with throwing the tubes to the center is you are increasing the chance for your opponents to grab it especially if you are the weaker drive. Yes there is some advantages with the lateral movement in front of the rack, but I'd take speed and pushing power over that. A properly built 6wd and 8wd will have a turn radius of zero and waste no power. |
Re: Mecanum or 6WD
6wd is the best because, not only is it faster and has more power, it can even be considered more manuverable than a mecanum. We tested this with our previous robots it takes 4 seconds with 6wd and 11 seconds with mecanum.
Re: Mecanum or 6WD
to do what?
Re: Mecanum or 6WD
Re: Mecanum or 6WD
Exactly! I was replying to someone who stated that only 4 cims can be used on the robot and only the four no other motors.
