Go to Post Have we all said "thank you for all you do" lately? :) - RoboMom [more]
View Poll Results: Mecanum or 6WD
Mecanum 90 40.36%
6WD 133 59.64%
Voters: 223. You may not vote on this poll
Unread 09-01-2011, 16:06
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Mecanum or 6WD
Mecanum has less traction, which will be key in this game. A good defender should be able to lock down the scoring zones--unless there are two robots attacking at once.
What would you say is a properly designed 6WD? With the middle wheel lower than the others in West Coast style?
Unread 09-01-2011, 16:16
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: Mecanum or 6WD
A little definition: West coast drive means that the wheels are cantilevered (unsupported on one end). 6WD is usually implied that the middle wheel is lowered (usually between 1/8" and 3/16"). A way around this is to have equal diameter omni wheels on the outer wheels.
Originally Posted by Ryan_Davis View Post
The rules state that four motors is max just fyi.
You can use 4 CIMs <R45c> plus the rest of the motors in the kit of parts <R45a>, there's a special section about the RS motors (you can use up to four in any combo, even duplicates) <R45d)
This does not waste any power.
The only wasted power in a mecanum is due to the friction in the bearings in the rollers.
My bad, you're right.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
