Go to Post I just weighed myself and I have gained two pounds since last Saturday. Thats a sign of a good robotics team. - russell [more]
Unread 09-01-2011, 15:52
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
Re: Is Labview Supposed to Be on The reimage?
Originally Posted by kinganu123 View Post
That sucks...
Just do another reimage
And make sure you change back you boot options to HDD after you're done with the usb
UPDATE
Wait, that's what you got AFTER deleting the recovery and extending the partition?
yeah, im going to try just formanting it; i might have corrupted the mbr.. il just keep messing around since i we have a copy
Unread 09-01-2011, 15:59
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
That's just an exe file made in labview. At least, it was last year. Therefore, you can't conclude that labview is on the computer.
Eh, I jumped the gun on that conclusion. But you do need the LabVIEW runtime to use native compiled LabVIEW exe's. So maybe we have the runtime environment but not actually LabVIEW.
Unread 09-01-2011, 16:02
yeah we got the runtime environment but not the actual labview..
we have the vision app and etc but not the actual program
Unread 09-01-2011, 16:12
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
that actually kind of sucks.
Unread 09-01-2011, 16:15
did some snooping well its right in our faces.
select disk 0
select volume 0
set ID=27 override
exit
is on the usb key as a file called HIDERECOVERY.txt -___-
and also
select disk 0
clean
create par pri size=5500
assign letter=R
format fs=ntfs quick label=Recovery
Create par pri size=100
active
assign letter=S
format fs=ntfs quick label=System
Create par pri
assign letter=W
Format fs=ntfs quick label=Windows
about to test a simple fix
make HIDERECOVERY.txt a blank file
and
remove
assign letter=R
from DISKPARTSCRIPT.txt
lets see if it works..
Unread 09-01-2011, 16:22
and also
and
remove
Keep us updated.
Unread 09-01-2011, 16:28
well i found out the R drive is where it caches the install image when its reimaging which is the partition i removed.. lets try without the hiding file. i guess il have to keep it separated.. if any body know about diskpart; post up.. im going to try to let it use that partition and then when it goes to hide it, reformant and extend the windows partition..
Unread 10-01-2011, 01:55
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I'm going to re-image, as I believe we made a mistake with the user accounts. Somehow we ended up with 3.
This is just a result of the Windows 7 setup wizard. The wizard has you create a new user account the first time you boot after imaging from the thumb drive. You can just log into the developer account and delete the 3rd one.
Unread 10-01-2011, 10:35
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
To officially answer the original question. No, LabVIEW is not supposed to be on the image. It was never intended the classmate be your development machine. If you want to install it on the classmate, the easiest way might be to copy the NI DVD to a USB thumb drive.
Unread 10-01-2011, 11:59
on mine theres no programming programs.. and the laptop is repartitioned into 10gigs and only 1gb is free.. and a 5 gig recovery partition with nothing on it... im wondering if i can formant that recovery partition.
I'm guessing you have a 2010 classmate? It would be good to make that clear, since rookie teams get a new classmate. I'm not seeing this on the new classmate. I'll try it on a 2010 class when my restore key returns.
Unread 10-01-2011, 12:36
The same thing occurred on our 2010 classmate. The drive is only 16gb. A 5gb recovery partition isn't an issue on the 2011 classmate with the larger drive, but it leaves the 2010 classmate with very little free disk space.
Unread 10-01-2011, 13:06
Oh boy.... :\
Unread 10-01-2011, 15:11
I just tried something that worked for me... now my C: drive has 6.6GB free.
I edited the DISKPARTSCRIPT.TXT file on the 2010 image key and changed the 5500 size of the recovery partition to 100.
Next, I edited the AUTOINSTALL.CMD file on the key...
I deleted the following line:
ROBOCOPY \ R:\RECOVERY\ INSTALL.WIM /R:5 /W:5
I then edited the next section to look like this:
ECHO Applying image...
IMAGEX /APPLY \INSTALL.WIM 1 W:
I'm not sure if there are any negative side effects of doing this, but it seemed to work for me the one time I tried it (on a 2010 classmate).
-Joe
Unread 10-01-2011, 23:15
-Joe
smart man, il try it when i get back to the room
Unread 11-01-2011, 00:12
A Tech's Avatar
A Tech A Tech is offline
Labview Programmer
AKA: Aaron Sandford
FRC #1165 (Team Paradise)
A Tech is an unknown quantity at this point
Send a message via Yahoo to A Tech
Maybe i can shine some light on this.
The small laptop doesn't come with the labview. i know it sucks ,
BUT they come with the CD and you can put it on another computer (I.E. laptop or desktop)
We are selfs have members of the programming team bring them in their own. we currently have 4 with labview and working fine. the mini laptop we are only using as the driver station and only for the driver station. beside who wants to program on such a small screen.
(any questions on how to set up your personal laptop to program and download the code to the robot just ask )
