Go to Post There's no problem another CIM motor wouldn't fix! - Tom Bottiglieri [more]
Unread 09-01-2011, 16:31
Re: Swerve??
Have you any prior swerve experience?
If not, I'd recommend not trying it at this point in time. It's really difficult to get working in the 6 weeks if you haven't done it before. Mechanical parts are "easy", especially with the Wildswerve. Programming? I think you'd better go catch your programmers, they already fled at the thought of only six weeks to do the code for the swerve and the rest of the robot.
Unread 09-01-2011, 16:33
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Re: Swerve??
Yeah the programming aspect of it is what makes it hard (it would require a lot of trial and error). I would suggest looking at an alternate design, unless you really feel like you can do it.
Unread 09-01-2011, 16:39
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: Swerve??
Yes we have had prior experience with swerve. We would not be moving them all 4 with a different motor. We will use 1 motor to 2 modules.
Unread 09-01-2011, 16:42
Re: Swerve??
The kinematics of swerve are completely understood. The only trial and error would be adjusting tuning parameters, and perhaps trying different driver interfaces to see which works best for your drivers and this particular game.
Unread 09-01-2011, 17:29
kwojcik kwojcik is offline
kwojcik is a splendid one to beholdkwojcik is a splendid one to beholdkwojcik is a splendid one to beholdkwojcik is a splendid one to beholdkwojcik is a splendid one to beholdkwojcik is a splendid one to behold
Re: Swerve??
Programming wise... encapsulate a motor and a potentiometer with a PIDController(it's in WPILib) into some object. Now you have a re-usable servo-motor object that you can use everywhere (arm, kicker, swerve drive, turret, etc) and all you need to do is tell it where to go. Spending some time understanding how this works will help tremendously for years to come!
Unread 09-01-2011, 17:40
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Swerve??
If improperly implemented it can be jerky and (insert other negative adjectives here). But that is not an inherent quality of swerve drive.
What EricH said: Build Season is not the time to teach this aspect to yourselves.
Try this: Ask what capabilities you are trying to gain with a swerve drive, and brainstorm "other" ways of accomplishing those capabilities. Then pick the one you can reasonably implement.
