Go to Post Does this mean it's too late to ask for a flux capacitor? - Peter Matteson [more]
Unread 09-01-2011, 16:28
ACone ACone is offline
FRC #3840
ACone is an unknown quantity at this point
Rookie Laptop Help
I was going to use the USB Drive to format the notebook's memory, but I am not sure if there is something I am supposed to do or install first.
Unread 09-01-2011, 16:31
2829ron 2829ron is offline
FRC #2829
2829ron will become famous soon enough2829ron will become famous soon enough
Re: Rookie Laptop Help
Are you talking about formating the netbook? If so, plug in the thumb drive boot up the netbook and repeatedly press f11, this should bring up the option to choose your boot device. Pick the thumb drive and then it should boot off of that. Afterword there are some files to download but you don't need to before you boot the thumb drive.
Good luck,
David
Team #2829
Unread 09-01-2011, 16:55
FRC #3840
OK thanks
Unread 09-01-2011, 17:19
FRC #3840
Do I need to put Windriver on the notebook?
Unread 09-01-2011, 17:24
FRC #2829
What programing language are you using? I would recommend labview. That's what I use and I like it. I you use Labview that will be on the netbook after you image it. I would recommend using a separate computer to program the robot and just use the netbook for your driver station. You can PM me if you have any questions.
David
Team #2829
