Go to Post Note to self for next year, apply physics rather than "well, this SEEMS like it would work." - Karibou [more]
Unread 09-01-2011, 16:17
Team 2016's Avatar
Team 2016 Team 2016 is offline
Mighty Monkey Wrenches
FRC #2016 (Mighty Monkey Wrenches)
Team Role: Student
Team 2016 has a spectacular aura aboutTeam 2016 has a spectacular aura about
Bumper hight
My team and I have read the rulebook and we can't find how high does the bumper have to be from the ground?
Unread 09-01-2011, 16:20
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumper hight
Look again at the definition of BUMPER ZONE.
(since 2004)
Unread 09-01-2011, 17:23
vannade vannade is offline
FRC #2591
vannade is an unknown quantity at this point
Re: Bumper hight
Find in INTRODUCTION 1.6 Logmotion Glossary. One inch above the floor and seven inches above the floor.
Unread 09-01-2011, 17:27
StupidGeek StupidGeek is offline
FRC #1058
StupidGeek is an unknown quantity at this point
Re: Bumper hight
Your 6 inch bumper must fit in a window of 7 inches off the ground.
Basically your bumper must be 1 inch off the ground.
Unread 09-01-2011, 17:29
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
Re: Bumper hight
BUMPER ZONE – the volume contained between two virtual horizontal planes, one inch above the floor and seven inches above the floor.
RHS Senior 2011
Unread 09-01-2011, 18:40
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumper hight
I'd look at the bumper rules again. Bumpers are not 6" tall.
(since 2004)
Unread 09-01-2011, 19:46
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: Bumper hight
Then the rule is clearly saying that bumpers may not be lower than 1 inch from the ground or higher than 7 inches from the ground, measured from any point on the bumper. Same as 2010, there was a range.
Almost worth a Q&A, but I thought it was rather clear.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 09-01-2011, 19:50
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Bumper hight
I see no need for a Q&A. The 5 inch bumper needs to be betweent 1 inch and 7 inches off the ground. It can be 1-6, 2-7 1.5-6.5 or any other combination.
- Arizona North
Unread 09-01-2011, 19:52
Re: Bumper hight
From R7
B. The BUMPERS must be located entirely within the BUMPER ZONE when the ROBOT is standing normally on a flat floor, and must remain there (i.e. the BUMPERS must not be articulated or designed to move outside of the BUMPER ZONE).
And...
From Section 1-Introduction (definitions)
A correctly constructed bumper should be a little over 5" high.
