Go to Post In my 30 year career, one thing I have learned is that if you truly enjoy your work, you'll be good at it. - DonRotolo [more]
Unread 09-01-2011, 00:15
Nishant Nishant is offline
FRC #0008 (Boeing and Palo Alto High School Robotics)
Team Role: Electrical
Nishant is an unknown quantity at this point
2011 Minibot electronics
Can you make your own logic circuitry to control the minibot instead of using the controllers?
Thanks,
Nishant
Unread 09-01-2011, 01:38
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: 2011 Minibot electronics
Let's expand on that. What are the wiring requirements for the minibot? Do we have to use a motor controller? What type fusing?
So many questions about the minibot, and no answers that I've been able to find in the documentation.
Unread 09-01-2011, 01:45
ratdude747's Avatar
ratdude747 ratdude747 is online now
Official Scorekeeper
AKA: Larry Bolan
I think you have to use the NXT brick or hardwired switches. see R92:
The following items are the only permitted materials for use on the MINIBOTS:
A. TETRIX components,
B. no more than two motors (PN
W739083),
C. exactly one 12V rechargeable
NiMH battery pack identical to
those supplied in the FTC kit of
parts (PN W739057)
D. No more than one HiTechnic DC
motor controllers,
E. No more than one NXT controller
with the Bluetooth functionality
disabled,
F. Polycarbonate,
G. Polycarbonate glue,
If an observation is made that aQRWKHUWHDP¶V52%27PD\EHLQYLRODWLRQRIWKHUR ERW
rules, please approach FIRST officials to review the matter in question. This is an
area where Gracious Professionalism is very important© FIRST 2011 FRC Game Manual, Section 3 ± The Robot, Rev- Page 31 of 32
H. Aluminum sheet, 90° angle, uchannel, tube, bar,
I. rivets,
J. non-metallic rope or cord,
K. wire nuts,
L. cable ties,
M. limit switches,
N. no more than two common
household light switches,
O. wire of appropriate gauge (see
Rule <R40>),
P. non-slip pad,
Q. PVC or CPVC pipe,
R. PVC cement or cleaner,
S. Mechanical hardware (i.e.
screws, bolts, etc) ,
T. Loctite or similar thread-locking
product,
U. Rubber bands,
V. Surgical tubing,
W. Electrical tape and shrink tubing,
X. PWM extension cables,
Y. Universal security clips to hold
the PWM connectors together,
Z. Hook and loop fastener (may not
be used as tape), and
AA.Magnets.
my vote would be for the nxt brick...
Unread 09-01-2011, 01:52
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
If I am understanding the manual correctly, I thought I could hook up a circuit consisting of a battery, light switch, and motor? Legal by R92 because there is no more than one controller.
Unread 09-01-2011, 08:04
Please check sections
4.3.14 MINIBOT
4.3.15 MINIBOT Inspection
If you use a controller it must be an NXT controller.
<R92> The following items are the only permitted materials for use on the MINIBOTS:
E. No more than one NXT controller with the Bluetooth functionality disabled,
Unread 09-01-2011, 12:26
JohnHorton's Avatar
JohnHorton JohnHorton is offline
Shock Test Dummy
FRC #1100 (Tomahawks)
JohnHorton will become famous soon enough
It seems like one could build it without any "brains" at all. In fact, I think a KISS design with, say, a light switch turned on by the hostbot and turned off when impacting the target, rigged to a motor directly might be the best idea. They were very specific about having " exactly one 12V rechargeable NiMH battery pack...", so it would seem they want this to be electrically driven as opposed to something mechanically launched from the hostbot.
Unless you just stick a battery on your projectile minibot. That'd be legal.
Unread 09-01-2011, 13:57
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
I think the battery statement is vague. Do you read it as the mini bot MUST have a battery?
It seems we could build a recoil motor with the surgical tubing??
Hmm
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 09-01-2011, 14:30
Jester Jester is offline
Labview Maniac
AKA: Cody Ripley
FRC #3144 (Krypto-Knights)
Jester is an unknown quantity at this point
where might I find these ftc parts?
Unread 09-01-2011, 16:19
JoesephWhite's Avatar
JoesephWhite JoesephWhite is offline
Alumni, Mentor for 2341 & 4612
FRC #4612 (RoboRockets)
JoesephWhite is an unknown quantity at this point
http://shop.pitsco.com/store/default...=1&page=1&s=32
Unread 09-01-2011, 17:29
peter1626 peter1626 is offline
FRC #1626 (Falcon Robotics)
peter1626 is an unknown quantity at this point
I am a little confused by R92 it says that you are allowed 1 12v battery pack and 1 NXT controller, but the NXT requires 6 AA batteries thats 9 volts, so does this mean we are allowed to use both the NXT WITH its standard battery in addition to a 12V FTC Battery pack or do we have to somehow modify the NXT?
2010 SBPLI Long Island-Regional-Imagery Award in honor of Jack Kamen
2011 New York City Regional-Industrial Design sponsored by General Motors
2011 SBPLI Long Island Regional-Regional Winner
Unread 09-01-2011, 17:46
JohnHorton's Avatar
Shock Test Dummy
Well, a 9v regulator would work, but that isn't listed on the components allowed.I find it kind of odd they don't allow basic electronics (resistors, caps, etc.) for the minibot. Correct me if I'm wrong.
I think a simple DC loop of Battery - Lightswitch - motor(s) - back again might be the best, as far as electronics go.
Unread 09-01-2011, 19:41
Since R92 is a list of the permitted parts and the NXT requires the AA battery pack, I would expect that those batteries would be legal. Since the only motors allowed are Tetrix motors that cannot be driven directly by the NXT, the NXT battery will not provide power to drive motors. (See above post of R92)
Unread 09-01-2011, 19:46
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Maybe it's time to teach the students how to make a speed controller (1/2 H-bridge....since all we want is a one-way trip (powered, at least!))
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 09-01-2011, 19:52
ATannahill ATannahill is offline
AKA: Alex Tannahill
You can have your one way trip, I don't want the field reset team to pull out a shotgun to get our minibot down.
- Arizona North
Unread 09-01-2011, 19:53
Is it legal to have a tether wire between the robot and the minibot? Wires are allowed in R92X, but I'm not clear whether or not the sizing box in R91 precludes them.
My apologies if this has been discussed elsewhere, it is impossible to follow all these threads!
