Go to Post We are not here to build robots, or to win a contest, or to travel to cool places or to bring home trophies. we are here to see what a career in engineering and science is like; anything else that happens along the way is frosting on the cake - KenWittlief [more]
View Poll Results: Mecanum or 6WD
Mecanum 90 40.36%
6WD 133 59.64%
Voters: 223. You may not vote on this poll
Unread 09-01-2011, 17:20
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: Mecanum or 6WD
Speed: Equal
Maneuverability: Mecanum
Traction: 6WD
Difficulty in Design: Mecanum
Power Consumption: equal
I disagree with difficulty in design. The programming, as well as driver training is a much greater requirement for a good mecanum system (I have built an omnidirectional system before, and I say this even considering the availability of example code). The maneouvrability is also a lot tighter than you would think (strafing is not as much of an advantage as most people think). In the end, with a well designed system, it is driver skill, either way.
If I recall, 80%+ of championship Einstein robots have been tank drive over the years.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 09-01-2011, 17:46
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
Re: Mecanum or 6WD
First: I think he was saying difficulty in design is greater for mecanums.
Second, I think that when the safe zone is only seven feet long (minus the 16" pegs for <6 feet), strafing could actually be really useful, especially since an effective defender will just body block in front of where they know you're going to put the tube. With a mecanum you can sort of get in from anywhere and sidle over, with tank that takes quite a bit longer.
Third, I agree that while each system is stronger than the other in certain respects neither is inherently superior.
Unread 09-01-2011, 17:48
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Mecanum or 6WD
6WD for 2 reasons: First is pushing power, second is "we've never done Mecanum before".
Unread 09-01-2011, 18:25
Ryan_Davis Ryan_Davis is offline
FRC #3157 (Iron Lancers)
Ryan_Davis is an unknown quantity at this point
Re: Mecanum or 6WD
Originally Posted by BrendanB View Post
You can have a max of 4 cims plus the motors included in the kop.
I would go with 6wd over mecanum in a heartbeat. Mecanums as mentioned have no pushing power and you won't be driving as fast around the field either. One problem with throwing the tubes to the center is you are increasing the chance for your opponents to grab it especially if you are the weaker drive. Yes there is some advantages with the lateral movement in front of the rack, but I'd take speed and pushing power over that.
A properly built 6wd and 8wd will have a turn radius of zero and waste no power.
The rules say:
<R45> Motors specifically permitted on 2011 FRC ROBOTS include:
A. all motors, actuators, and servos listed in the 2011 KOP Checklist,
B. an unlimited number of COTS servos with a maximum power rating of 4W ,
C. one or two CIM motors in addition to
those provided in the KOP. This means up to four CIM motors and no more can be used on the robot
"Quality means doing it right when no one is looking."
-Henry Ford
Unread 09-01-2011, 18:38
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: Mecanum or 6WD
More reason to try it. This will be our team's 7th FRC season and we have done 6wd for each year, but we are heavily debationg 6wd vs. Mecanum.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 09-01-2011, 18:41
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Re: Mecanum or 6WD
It's a pretty board statement, but from my experience I'd have to say 6WD because a macanum bot will get pushed around easily.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 09-01-2011, 18:47
Charmander's Avatar
Charmander Charmander is offline
None #1714
Charmander can only hope to improve
Re: Mecanum or 6WD
This drive system team 2404 used is interesting... it has many of the characteristics of the mecanum drive system.
http://www.youtube.com/watch?v=pZf1-...eature=related
Unread 09-01-2011, 18:49
Charmander's Avatar
None #1714
Re: Mecanum or 6WD
This drive system 2404 is testing is interesting. It has many of the pro's that mecanum wheels have.
http://www.youtube.com/watch?v=JqJK0E9Jpmk
Unread 09-01-2011, 18:50
Chris is me's Avatar
AKA: Pinecone
Re: Mecanum or 6WD
I'm going to disagree with teams that go "mecanum = agility". Every year I see so many teams who say "oh we should be agile so we need a mecanum drive" and it drives me nuts.
First, agile is a very vague term. Mecanum has a specific kind of motion it can do that 6wd can't. The real question is do you need that kind of motion?
Second, it is very easy to underrate the "agility" of a 6wd system. It can turn easily on a dime and drive very well in that fashion. The only thing it can't do is strafe.
Essentially, the trade off is strafing sideways or resistance to pushing / pushing power. Which is more important?
Unread 09-01-2011, 18:54
Re: Mecanum or 6WD
The programming ... is a much greater requirement for a good mecanum system (I have built an omnidirectional system before, and I say this even considering the availability of example code)
What part of the programming of mecanum did you struggle with?
Unread 09-01-2011, 19:24
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Mecanum or 6WD
We have done 6WD and mecanum, both have advantages. I do think that given the depth of the scoring zone, a mecanum drive could be a big advantage. Furthermore, while mecanum drive robots are easier to push around, I have found them to be more difficult to block. The ability to always be able to move directly away from a blocker is very nice. It makes it much more difficult to continuously block the robot.
All that said, the best drive train we have produced was probably for Rack 'N' Roll, a 6WD with omni wheels on the "front" (read: the end where the tube is dangling) and the other four wheels (aft and a little aft of center) were traction wheels. That year we geared for torque over speed, which served us pretty well. The base of our arm gave the back end a lot of traction, but the whole thing spun really close to in place.
Side note: If you choose to do a one speed mecanum system you have to give yourself enough torque. We had quite a few problems in Overdrive with motors overheating because we didn't have enough torque when strafing.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 09-01-2011, 19:33
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: Mecanum or 6WD
I see the same exact thing! It makes me confused. I would not consider mecanum more maneuverable also. The only trade-off is pushing power to strafing.
Well stated.
Unread 09-01-2011, 19:54
ThaineP
Posts: n/a
Re: Mecanum or 6WD
How about Mechanum6? It could be like this:
So that there are six wheels, where the front and back pairs are Mechanum, and the center pair is straight Omnis. It seems like it could be possible, so it may not work.
Just an idea.
Thaine
Unread 09-01-2011, 20:32
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Mecanum or 6WD
Just an idea.
Thaine
like this?
I assume it would allow you enough traction to effectively push other mecanum bots, but thats about it.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 09-01-2011, 20:35
Re: Mecanum or 6WD
Originally Posted by Jeffy View Post
like this?
Maybe they needed the omni's to assist rotation since the mecanums are mounted incorrectly.
