Go to Post ... Imagine NOT being able to count on certain things to stay the same from year to year... It makes you wonder what sort of sick, twisted mind would do such a thing to all those innocent teams out there... - dlavery [more]
Unread 09-01-2011, 18:01
MBunzel MBunzel is offline
FRC #3238
MBunzel is an unknown quantity at this point
<R45> maximum amount of motors
are you aloud to have 4 CIM motors and 4 BaneBots motors or a combination of both that would be equal or grater than 4? ive read this rule many times and am still baffled by it. help would be appreciated!
Unread 09-01-2011, 18:05
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: <R45> maximum amount of motors
I'm going to be perfectly blunt and say I don't believe you have read that rule in its entirety.
R45 C and D answer the question.
C. one or two additional 2½” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the KOP. This means that up to four, and no more, 2½” CIM motors can be used on the ROBOT.
D. up to four, in any combination, of the BaneBots motors provided in the KOP (RS-775, RS-550, RS-540, RS-395),
I read, and believe the GDC mean, up to 4 cims, and up to 4 BameBots.
- Arizona North
Unread 09-01-2011, 20:34
FRC #3238
ok, thanks i did read those parts and what you said is what i thought, i just wanted someone else's thoughts on it
Unread 09-01-2011, 21:55
GEARmaster08's Avatar
GEARmaster08 GEARmaster08 is offline
FRC #0876
GEARmaster08 is an unknown quantity at this point
So are the F-P Motors in the BaneBot Category of Motors? Or how many of them can we have?
Unread 09-01-2011, 21:56
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
No, an FP is an FP. You can use the one that came in the KOP.
Unread 09-01-2011, 22:25
FRC #0876
So one and only one FP can be used?
Unread 09-01-2011, 22:28
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
yes...
Unread 10-01-2011, 09:55
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
On a more comical note, something tells me we're going to see a 8-motor drive train this year that has 4 CIMs and 4 BB-550s.
Imagine the pamphlet for such a drive train...
Blazing around the field with 2200 watts of powa!
Able to suck a FRC battery dry in 0.66 seconds!
20 ft/s!
GitHub
Unread 10-01-2011, 11:02
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
20 ft/s!
How did you get access to 1712's promotional materials already?
Unread 10-01-2011, 11:18
ebarker's Avatar
ebarker ebarker is online now
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
In terms of raw power, why would you choose a 550 over a 775 ?
In terms of durability, is the 775 better than a 550 ?
Peak efficiency data only is listed below, measurements at 12 VDC.
RS-775 - 119W, 11360 RPM, 12.5 A, 14.2 oz-in
RS-550 - 99W, 17100 RPM, 10,91 A, 7.9 oz-in
RS-540 - 49W, 14840 RPM, 5.85 A, 4.5 oz-in
RS-395 - 25W, 13110 RMP, 2.74 A, 2.6 oz-in
Ed Barker
