Go to Post Cheaters never win, winners never cheat. :) - Amanda Morrison [more]
Unread 09-01-2011, 01:26
Enjin Enjin is offline
FRC #3271
Enjin is an unknown quantity at this point
Regarding the DEPLOYMENT LINE
Is it only the HOSTBOT that has to be below the DEPLOYMENT LINE or does the HOSTBOT/ MINIBOT combo be below the DEPLOYMENT LINE. In other words, can the base of the MINIBOT be at the DEPLOYMENT LINE or is the top of the MINIBOT that can be at the DEPLOYMENT LINE?
Unread 09-01-2011, 01:34
Re: Regarding the DEPLOYMENT LINE
I'm not certain from a reading of the rules either. Guess that's one for the Q&A file.
Unread 09-01-2011, 01:42
Randy Picolet's Avatar
Randy Picolet Randy Picolet is offline
Caffeine Addic..um..Afficionado
FRC #2159 (RoboPirates)
Randy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud of
<G22> HOSTBOTS may not contact their ALLIANCE’S MINIBOT once it has climbed above the DEPLOYMENT LINE. Violation: TOWER is disabled
I think this (combined with other defs/rules) is intended to mean you have to deploy completely (host and mini) below the deployment line, and then the minibot can start climbing but the host better not be pushing/following/touching the mini as it starts to cross the line. Maybe some clarification needed, but that seems like the idea we should all be going for...
Unread 09-01-2011, 01:56
(emphasis mine)
That is the safest plan for sure. Start low, and if you're allowed a little height, you can take it--but only if you like living dangerously.
Unread 09-01-2011, 11:40
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
My interpretation of this was that the mini-bot must not be above the deployment line until it is disconnected from the host-bot.
It says nothing about the host bot not being able to be above the deployment line. How would you do that anyway if you were trying to place tubes on the top level anyway (I am sure there is a way to do that, but it would be unnecessary)?
So in conclusion, the mini-bot must be completely below the deployment line when the host-bot is deploying it. The second the host-bot deploys it and is not touching it, it is allowed to travel above the deployment line.
Agreed?
Unread 09-01-2011, 11:54
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Originally Posted by Cyberphil View Post
Agreed?
That's the way I read it as well.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 09-01-2011, 12:04
cyberjoek cyberjoek is offline
AKA: Joe Kavanagh
no team (Event Volunteer)
cyberjoek is just really nicecyberjoek is just really nicecyberjoek is just really nicecyberjoek is just really nice
Send a message via AIM to cyberjoek
This is all IMO:
The rule that establishes this is rule G20:
<G20>ROBOTS/HOSTBOTS may not contact their own TOWERS above the DEPLOYMENT LINE.
Violation: PENALTY for contact. TOWER is disabled if MINIBOT is DEPLOYED above the DEPLOYMENT LINE.
And just so we're clear:
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference during the END GAME. (Related form, DEPLOY, verb)
The definition of Deployment/Deploy/Deployed seems to indicate it is the whole action which would include the whole bot.
By my reading if any part of your Minibot is above the line during the act of positioning a MINIBOT on a TOWER you've just DEPLOYED above the DEPLOYMENT LINE. That means if you're above the line during the DEPLOYMENT you're the proud owner of an ex-tower.
Unread 09-01-2011, 15:43
Cyberphil's Avatar
That Guy
AKA: Phil
Originally Posted by cyberjoek View Post
This is all IMO:
Where does this indication you see? I see nowhere in any of these rules where it says the host-bot must also be below the deployment line. The only bot that it refers to on the deployment line is the mini-bot. I do not think the GDC would be so evil as to make you below the 30" mark also when deploying your mini-bot.
Unread 09-01-2011, 15:53
This is all IMO:
ROBOT = HOSTBOT + MINIBOT.
<G20> is saying while the host/mini are in contact with each other, neither may touch the tower above the deployment line. The violation clause says that in addition to the penalty, if the minibot is also postioned above the line then it is disqualified from the race.
Unread 09-01-2011, 16:15
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
The question that we need the answer for is what defines positioning. If one flings the minibot from ground level, and it first touches the pole at 50 inches, above the line, is that counted as illegal deployment.
Unread 09-01-2011, 18:14
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is online now
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
I think the term DEPLOYMENT should be defined more clearly in the glossary section. It includes the statement "DEPLOYMENT starts when..." but I feel that it should also include "DEPLOYMENT ends when...". Is it when the Minibot touches the pole? When the Minibot reaches the deployment line? When the Minibot is no longer supported by or touching the Hostbot? This would help with clarity with a few of the rules, some very significant to the mounting or possible propulsion of Minibots.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 09-01-2011, 21:50
AKA: Joe Kavanagh
I've been on a flight which gave me a bunch more time to nerd out with the manual and here's what I've found:
1. ROBOT = HOSTBOT + MINIBOT (as per the last sentence of the definition)
2. DEPLOYMENT – the act of positioning a MINIBOT on a TOWER.
3. MINIBOT - the autonomous vehicle designed as per 4.3.14*
Now, replacing some of the glossary words from their definitions
<G20>[HOSTBOT + MINIBOT]/HOSTBOTS may not contact their own TOWERS above the DEPLOYMENT LINE.
Violation: PENALTY for contact. TOWER is disabled if [the autonomous vehicle designed as per 4.3.14] is [positioned on a TOWER] above the DEPLOYMENT LINE.
Let's say you position your minibot with top 5" of it above the line and bottom 5" below. You are completing the act of deploying your MINIBOT both above and below the line. The act of positioning (DEPLOYMENT of) the MINIBOT has occurred above the line so you are the proud owner of an Ex-tower.
Looking forward to what the GCD has to say about this.
This rule needs lots of clarification because technically any minibot making the climb will get a PENALTY because it's touching the TOWER above the DEPLOYMENT LINE as it makes its climb and it's part of the ROBOT as defined within the first part of the rule.
*I'm assuming the 3.4 is a typo and we aren't getting a new major subsection inside The Game.
