Go to Post If your prototype works perfectly, you've been working on it too long. - Blair Frank [more]
Unread 09-01-2011, 18:09
Ultramadscienti's Avatar
Ultramadscienti Ultramadscienti is offline
Is experimenting
AKA: Cameron M
FRC #0179 (Children of the Swamp)
Team Role: Student
Ultramadscienti has a spectacular aura aboutUltramadscienti has a spectacular aura about
Send a message via AIM to Ultramadscienti
Catapult Construction
My class is making catapults to demonstrate physics and whatnot. We only have to be able to toss a tennis ball 8 feet, I can do that; however I want to be able to launch a bowling ball 20 feet (to impress my favorite teacher). I would like to know what you would suggest as the component that would provide the force.
(>O_____________________________o)> ~ whale hug
Unread 09-01-2011, 18:46
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Catapult Construction
Catapults are powered by springs or the like, as compared to a trebuchet which uses a weight and gravity.
Some ancient catapults used several strands of heavy rope, attached to the frame and the arm, which were tensioned by turning a ratcheting mechanism on the frame. You can see the twisted rope surrounding the axle in this image.
Other catapults used the energy stored in the bending of the arm. See how this wooden arm is bent after being pulled down by the rope?
In ANY CASE, be sure to consider what will happen when the arm breaks. Release mechanisms must be operable from a distance, and much stronger than you think. Make sure you stay safe please.
Unread 10-01-2011, 16:11
Is experimenting
AKA: Cameron M
Team Role: Student
Would rope or surgical tubing make a better mechanism for making the arm swing?
Unread 10-01-2011, 22:22
DonRotolo's Avatar
Back to humble
FRC #0832
That's for me to know and you to (experiment and) find out.
Unread 11-01-2011, 15:49
Is experimenting
AKA: Cameron M
Team Role: Student
Curse thinking for myself, curse it to... actually I should run a script to see how would be the most efficient way to curse it.
Unread 11-01-2011, 17:42
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Apparently there are many many different ways you can make a catapult: http://science.discovery.com/tv/punkin-chunkin/
Unread 11-01-2011, 20:15
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Trebuchets ARE catapults. The difference is trebuchets are gravity powered catapults rather than torsion catapults. Also, despite the bend in the arm, the second picture appears to be a trebuchet, or a hybrid catapult.
You will probably get more out of surgical tubing then rope. Using both might be even better. also, not to discourage you, but bowling balls can break if dropped/bounced. It happened once on Mythbusters.
Unread 11-01-2011, 21:42
DonRotolo's Avatar
Back to humble
FRC #0832
That would be cool. Post the results here.
Yeah, maybe, but I picked that image because of the bend in the arm, nothing more.
Catapults are a class of things to fling things. Trebuchets are in the Catapult class. Do not fling cats, please (even though they make a wicked cool "pult" sound when they hit)
No animals were harmed in the making of this post.
