Go to Post You can either suck up a lot of oxygen, or you can contribute to our communal knowledge. The choice is yours. - dlavery [more]
Unread 09-01-2011, 20:10
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
removed classes from wpilib
I tried loading the code base from last year and noticed that there are quite a bit classes missing now. This includes things like the RobotDrive class and the DigitalInput class. I just wanted to give programmers a heads up that once you update, last years code may not work.
*and as always, remember if you plan you use last years code you MUST open source it
Unread 09-01-2011, 20:17
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: removed classes from wpilib
yes i have noticed this too, it is quite strange, there will be no arcade drive this year im assuming saying thats whats missing from our code?
Unread 09-01-2011, 20:18
Slix Slix is offline
AKA: Peter Kowalczyk
FRC #2115 (NightMares)
Slix is an unknown quantity at this point
What? That seems odd. I was looking through the C++ documentation that detailed all of the classes, and RobotDrive was included. And I'm sure it's not an outdated version because it includes the new Watchdog replacement.
http://firstforge.wpi.edu/sf/go/doc1198?nav=1
Unread 09-01-2011, 21:19
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
I think that MUST should read "SHOULD HAVE ALREADY open sourceD it". If you haven't already open sourced it at this point, I think you are too late. The competition started yesterday.
Maybe Chief Delphi should have an open source announcements forum just for this purpose.
-T
Unread 10-01-2011, 01:42
imac256 imac256 is offline
AKA: Ian McInerney
FRC #2022 (Titan Robotics)
imac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of light
Where in the rules does it talk about being allowed to use open source code? I looked through the rules and couldn't find any reference to it. I remember that last year they had a rule saying any open source code was considered COTS, but I can't find that for this year.
- Ian McInerney
Alumni & Mentor, Team 2022 Titan Robotics
Junior, Iowa State University majoring in Electrical Engineering
Unread 10-01-2011, 01:49
mwtidd's Avatar
AKA: mike
a COTS item is something you can get from a distributor and can be made available to and supplied to every team if need be
software free or not falls under this definition
Unread 10-01-2011, 02:09
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
In the first section of the manual there is a glossary that defines COTS parts. Specifically in section 1.6 COTS the note says
For the purposes of the FRC, generally available software modules obtained from open sources (e.g. professional publications, commonly used FRC community accessible web resources, industry source code repositories, etc.) that are not specifically affiliated with individual FRC teams shall be considered COTS items.
Unread 10-01-2011, 03:18
I looked at this years WPILib manual that has doxygen documentation of all the classes. I saw RobotDrive included.
Unread 10-01-2011, 03:56
mwtidd's Avatar
AKA: mike
I think it's all set now. They were having issues before with having the most recent release ready. Seems to be fixed.
Unread 11-01-2011, 02:40
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
You have some other problem. None of these classes were removed.
-Joe
Unread 11-01-2011, 02:47
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Use the following if you want arcade drive. Tank drive is easier.
Linear Arcade drive:
int m1 = 0; //Temp Variables
int m2 = 0; //Temp Variable
int x = 0; //Joystick X
int y = 0; //Joystick Y
Joystick JoyHoy = new Joystick(1);
PWM motor1 = new PWM(1);
PWM motor2 = new PWM(2);
I usually declare and initialize separately like I do for C++, but for simplicity sake I didn't.
while(teleop) //arbitrary while loop, its the teleop
Y = JoyHoy.getY();
X = JoyHoy.getX();
m1 = 127 * y + 127;
m2 = 127 * y + 127;
motor1.setRaw((int)(m1 + m1 * x));
motor2.setRaw((int)(m2 - m2 * x));
edit:
also regulate the PWM, as is, the code will generate invalid PWMs
Unread 11-01-2011, 04:43
thepcphysician thepcphysician is offline
FRC #1678
thepcphysician is an unknown quantity at this point
On the topic of WPILib changes, they changed "SetLeftRightMotorSpeeds" to "SetLeftRightMotorOutputs" without updating the documentation. Took me an hour of compiler errors before I finally looked in RobotDrive and figured that out.
Unread 11-01-2011, 12:25
Which document is not updated? We'll get that fixed.
Unread 12-01-2011, 02:31
FRC #1678
Page 35, WPI Robotics Library User's Guide, January 5th, 2011. Are you with WPI?
Unread 12-01-2011, 02:48
No, but I'm one of the developers of WPILib for C++.
